No screws in back of swan washing machine to remove the back to change the belt sw1020
  • 3,506 Answers
Then the front comes off or you access it from the bottom.
Posted on Nov 08, 2014
AlmostBob
  • 550 Answers
SOURCE: Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Posted on Oct 13, 2008
  • 566 Answers
SOURCE: How do I remove the back cover on the washing machines?
removed screws from top / bottom and sides? then pull top pcover back slightly and lift at rar to clear back cover manouver the flex drain pipe as you remove panel ?
Posted on Nov 01, 2008
  • 197 Answers
SOURCE: Washing machine won't spin
I think it's the capacitor. The capacitor live under the top of the washing machine, two screws, and measures about 7"x2". The capacitor gives the drum An extra 'bump' when all the weight is in It. Remove the capacitor with a pair of pliers or a spanner but under NO circumstances, touch the two connections at the to of the unit, you will get one hell of a shock! Run the machine empty with the top off and it should run properly.Then refix the top. Job done,
Posted on Jul 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Posted on Jul 25, 2010
  • 2699 Answers
SOURCE: How do I remove the back of the machine on a Model
don't touch the back,there isn't a belt in kenmore washers and don't touch the back panel,there are white covers on each side of the top panel,pop them off and remove the two phillips screws,one on each side,then flip the panel up,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back to the wall and the clip will repease,now in the middle of the clips you'll see the lid switch connector,separate it,open the lid and grab the frame,tilt it up and back at you and remove the frame,on the bottom you'll see the pump,remove the two clips and pull off the pump,then remove the two screws and pop the two clips and slide out the motor,on the back of the motor you'll see the coupling,that's what broke,you need to replace the motor coupling
Posted on Oct 30, 2010
User manual sw2051w
The SWAN (SWAN Laundry only) Help Line: 01189 252545 Monday-Thursday (9:00 AM-5:30 PM) Friday(9:00 AM-4:15 PM) You will need to tell them The Make: SWAN The Model:SW2051W
Good Luck! Swan is only warrantied in U.K. and Ireland!
Apr 23, 2016 | Sourcing Map Water Liquid Level Sensor for...
Tip
How to Install Washing Machine Belts?
The procedure is as follows:--
1) First of all unplug the washing machine from main power outlet.
2) Take it out away from wall.
3) Remove the screws from its back to remove the back panel.
4) You will see the belt once the back panel is removed.
5) Now push the belt adjustment lever towards the down side. so the belt will get loose.
6) Carefully remove the old belt.
7) Place the new belt in the same position as old belt was placed.
8) Refit all the parts in the same place and same order in what they were removed.
This will help. Thanks.
on Mar 15, 2010 | Washing Machines
How do I replace the fan belt on my swan machine if the back doesn't come off!
remove lid......put belt down the rear and lift it up.
cheers
Nov 01, 2014 | Washing Machines
How do I remove the back of the machine on a Model #11026892690 Kenmore 80 Series Washing Machine to change the belt?
Oct 30, 2010 | Kenmore Washing Machines
How do I change the belt on my hotpoint top load washing machine?
turn it back to you, there is an opening at the back, just remove the screw, you will see the inside of the body, at the bottom you will where is your driven belt located, loosen the foot bracket of the motor holding the belt so that you can remove it, just remeber the part number of the belt or much better bring it with so that you ca have an actual comparisson, different brands and model of washing machine have different types of belt
just to make it sure. bring it with you
when you put it back don't make it to tight, just enough that i won't slip once you turn it on.
Nov 01, 2009 | Hotpoint VVSR1070D Top Load Washer
How to open the back of Frigidaire FEX831CS to change belt.
Remove the two screws from the bottom of the FRONT panel. The panel drops down and pulls off. You change the belt from the front
Jul 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
Need instructions on how to change the belt in my washer
you have to take back off,,always unplug first..thats it just remove back take screws out all the way around back,,put belt on motor than spin drum pully...
Jan 06, 2009 | Washing Machines
Replace a belt on a amana dlw330raw
you flip the washer on its side
remove the screws on the side
take out the tub springs
remove the pulley
put the belt on bolt on the pulley
put the tub springs back hardest part in my opnion
replace the screws
test the washing machine
....it is no different than changing a belt on a car ....my best suggestion is that you take pictures at every step and stay organized...that way u can tell orientation of all the parts.
Dec 28, 2008 | Washing Machines
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
