Toshiba laptop emitting static sound from internal speakers and no sound through headphone jack
    New Friend:
  • 3 Answers
Your volume is maybe to loud turn it down a bit
Posted on Nov 08, 2014
5 Suggested Answers
SOURCE: headphone jack not working
I got it fixed from the hp customer support. I was chatting with the expert and he provided the same solution and it worked. I removed all sound drivers and installed the latest updates and it worked. I only have one more thing to be solved. That is, the internal speakers doesn't get muted when i plug-in the headphone. I am trying to fix it. I will post here if it is fixed.
Posted on Nov 05, 2008
janelu
  • 93 Answers
SOURCE: Toshiba Notebook L315 Headphone Jack Problems
the sound socket on the motherboard was nearly damaged, the only way can fix it is replaced the socket on motherboard by componnet level technician, otherwise you have to use USB port to sound out...
Posted on Nov 17, 2008
  • 1019 Answers
SOURCE: Laptop noise interference
This appears to be a problem with the soundcard or device. The mic/headphone/speakers are all usually associated with the sound card. you may have had a virus attack or problems with the items drivers. Check the device has no problems:- My Computer/Control Panel/System/Device Manager ( Yellow Exclamation ) denotes Problem. Alternatively, is to disable the Mic Input Via the sound cards control Panel.
Thankyou for using Fixya.
Mike @ compurepair.
Posted on Nov 26, 2008
  • 116 Answers
SOURCE: Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Posted on Dec 13, 2008
Toshiba L755-S5246 laptop emitting static sound through internal speakers and no sound through headphones.. Ideas?
From what you described, this sounds like a defective sound card. I would suggest bringing it into a professional to get it checked out. However, I could be wrong. If you can get it checked for free and then have it repaired for money, that would be my suggestion.
Nov 08, 2014 | Computers & Internet
Laptop headphone port not working
First of all check all driver/software settings, secondly ensure you have the latest driver for your sound device installed. Then proceed with the following:
Have you tried another set of headphones, did they work? Do you get sound from the internal speakers if nothing is plugged into the headphone jack? Do you still get sound from the internal speakers when you plug in your headphones?
If you answered yes to most of, if not all of those questions you are likely to need your jack socket replacing.
If you haven't tried another set of headphones, or other 3.5mm jack audio device, do it and let me know the results.
If the answer is no to any of the other questions please let me know which ones and I will try to offer more advise.
Dec 07, 2013 | Computers & Internet
No sound on my macbook
Check if there is any sound coming out of the headphone (using headphone and playing itunes).
If there is none. Goto System Preference > Hardware > Sound > Output ; check if the output is assign to internal speaker and it is not muted.
Do a visual check at the headphone connector, look into it, see if you see a red light emit from the headphone jack (indicate that the fault is in the headphone connector, it's trying to output optical spdif).
Nov 28, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Sound coming through Dynadock is all static with faint sounds?
I had the same problem. I went to the Toshiba sight and downliaded all the drivers for Windows 7. I loaded the new dirvers. The first time that I restarted the laptop I had the same result. I turned off the computer overnight. When I came into the office this morning and turned on the computer it resumed audio without the static that you would normally hear whether with system sounds or the media player. It absolutely has to do with the drivers since the headphone jack works (dynadock not in the loop). I would reccommmend not just restarting but turnung the Laptop off and restarting.
Aug 05, 2009 | Toshiba Dynadock Port Replicator, Docking...
Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Jun 05, 2009 | Dell Inspiron 700m Notebook
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
