Question about Water Heaters
Looking for manual for Junkers gas geyser 250 KV3 P3152500TAI
  • 81 Answers
They all work the same
http://www.americanwaterheater.com/support/manuals/res-gas.pdf
Posted on Nov 11, 2014
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers gas geysers
What is a, "geysers pilot"?
Jul 14, 2014 | Water Heaters
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
What is an anode in a geyser
The anode rod is part of water heater, not part of geyser:
Here are anode rod resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
The geyser is compressor that attaches to top of water heater, and converts ambient room temperature into heat to heat water using the refrigeration cycle in reverse
Add a comment and fixya might notify me so i can more informeation if needed
Jul 08, 2013 | Water Heaters
Junkers gas geysers not heating water much
between 60 and 75 degrees c as any hotter will scald you. Have the gas specialist check it out as it may not be getting enough gas flow to the burner either a badly adjusted regulator or a blockage in the gas tap or line.. You control the temp by the amount of water coming out of the tap as you found out when you attempted to restrict the water flow.
May 29, 2013 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Water Heaters Logo
254 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
