Question about Amana RCS10TS - Commercial Microwave Oven - 1000 Watts
How do i can get the manual service
The microwen turn on but dont heat food, i change the magneron but dont heat still.
    Top Expert:
  • Amana Master
  • 34,089 Answers
Amana may supply a manual if you request it.
Posted on Nov 08, 2014
I have bought a logik fridge freezer its in garage which is attached to my house but in the fridge I have frozen tomatoes
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I can only advise in general terms.
The basic operation of a combo freezer/fresh food section unit are the same.
Generally, the fresh food section does not have a independent cooling source. It gets its cooling from the freezer section. There is a air damper from the freezer to the fresh food section. This air damper is controlled by a thermostat. I suspect that either the thermostat is bad or the damper. Your air damper is wide open.
The other problem is, your unit is not designed to operated in a garage. If you have a warrantee or a service contract it will be cancelled by the service company. Your electrical components can short out or corrode from the drastic change in temperature. Your control board can fail due to static in the air or condensate.
Feb 15, 2015 | Engel Coolers Combination Fridge and...
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
Frezzer keeps icein over
Hello;
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Where is the defrost timer on a frigidaire fghn2844lf2
Good Morning Debbie,
I see that you are looking to see what turns on the defrost timer and evaporator fan on your Frigidaire refrigerator, model# FGHN2844LF2. Your appliance comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, simultaneously press and hold the Fresh Food up (+) and Fresh Food down (-) keys for 5 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, simultaneously press and hold the Fresh Food up (+) and Fresh Food down (-) keys for 5 seconds. A "d" and "F" will be displayed until the defrost cycle is complete. I hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Food is starting to defrost in my hotpoint first edition
You may have to heat up the surrounding of the refrigerator so that the unit will work properly. Some manufacture have tempoerature limits that the units can operate in unles there's additional equiptment installed on the system. If you have access too it read your Owners manual and see if there is. Good luck and have a Happy New Year.
Jan 05, 2009 | Freezers
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Amana RCS10TS - Commercial Microwave Oven - 1000 Watts Logo
95 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Gil Shultz
John Tripp
John Tripp
Are you an Amana Freezer Expert? Answer questions, earn points and help others
