Question about Makita Saws
Wiring diagram for switch on Boschmann JIX JF7 255 /Makita Mitre Saw with part number 651923-1 (TG70B).
The switch is used for the Boschmann Mitre Saw and also used in Makita model LS1013 among others. I can't quite remember the way the wires are put back in to the switch. My saw has two black wires, a blue, brown and pale greyish wire. If I know which is the live wire then I could re-wire it. Could someone give me a pointer with this? I've had a look at circuit diagrams for Makita ones which uses the same switch but these have different coloured wires. Any help?
2 Suggested Answers
  • 304 Answers
SOURCE: wiring diagram for switch on makita mlt100 saw
ring Makita on 01908 210710 and ask for technical
Posted on Jun 05, 2012
Why doesn't the laser marker work on my Makita mitre saw?
contact Makita, it may be defective
, or they can troubleshoot. You can check on youtube.com for a possible fix also.
Mar 07, 2015 | Makita 10" Miter Saw LS1030N
How to fit compression spring on makita LS 1040 mitre saw
Go to: http://www.ereplacementparts.com/makita-ls1040-miter-saw-parts-c-97_98_99_323.html. They also have a video on how the replace the blade. Look closely at the parts diagram to see how and where the spring fits and fit accordingly.
Sep 09, 2014 | Saws
Ryobi 10 in Mitre saw with laser, switch / motor wiring diagram?
capacitors are known as capacitors or condensers. Both do the same job of storing electrical energy and then releasing it when the current flows back . They are used to either start an electric motor or stop arcing on the brushes by absorbing the current flow as it stops over each commuter bar of the armature
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
Makita LS 1212F brake
The brake on these saws is a controlled by the switch; it allows power to only one side of the field when you release the switch thus pulling the motor to a stop. In order to get your brake working again you have to replace the switch with Makita part number 651923-1, Switch TG70B. You can put in a generic switch that fits but the blade will spin slowly to a stop every time you release the switch, which you may have now.
Jun 29, 2012 | Saws
Wiring diagram for switch on makita mlt100 saw
May 30, 2012 | Makita Saws
Makita ls 1211
The 'brake' on tools like this is actually a function of the switch allowing some current to flow to one side of the armature to magnetically stop the motor & blade. If the motor works fine but it is no longer breaking you need a new power switch. You need Makita part number 651923-1 for an LS1211 saw.
May 21, 2012 | Saws
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
Jun 17, 2009 | Saws
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Hi, need to use drop saw. Have used many times, however husband usually around. He has now passed away, and I know this may sound ridiculous, but have plugged in and can't find power switch or catch to...
If this is a Makita Mitre saw the switch requires 2 operations to engage. First you should see a round button on handle, you need to depress the button and then pull the trigger. I would recommend doing this with the tool unplugged first so you get the feel for it. Second the release button is on the right hand side of the saw, what you need to do is push down on the saw head some and PULL out on the round pin to release. I would recommend also that you go to Makitatools.com and type in your model number and download a owners manual so you can see exactly how to use the tool. Let me know if you need any more help please.
Jan 08, 2009 | Makita 10" Miter Saw LS1030N
Saws Logo
53 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
