Question about Sewing Machines
<!-- from fixya rte -->How do I thread an elna 390b sewing maching - Sewing Machines
    Sergeant:
  • Sewing Machines Expert
  • 455 Answers
Google your machine make and model with Users Manual.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
  • 1116 Answers
SOURCE: how do you thread a elna L-5 sewing machine
I found two sites with a manual for this model. Both are around $15.00 - sew4less and sewusa.
If you open the front of the serger, there should be a threading guide printed on the serger or on the inside of the door.
Raise the thread antenna to it's highest position.
Set the tensions to zero and raise the presser foot.
Turn the handwheel until the loopers are at their highest position - the handwheel may have a mark on it that aligns with one on the side of the serger to help with this.
Starting at the right, thread the upper looper first.
After threading, reset the tensions back to approximately mid-range.
Lower the presser foot and stitch a chain of thread to make sure the serger is stitching as it should.
Posted on May 01, 2010
SOURCE: new 344 elna overlocker - can't thread lower
I have been dealing with the exact same problem for 2 hours and no answers!! I have just discovered that if you move the stitch width finger to R instead of N, your threader will work!! Hope this helps :)
Posted on Nov 30, 2010
rickead1
  • 1998 Answers
SOURCE: I need a manual.
well you could get the manual from this site http://safemanuals.com/user-guide-instructions-owner-manual/ELNA/6005-HEIRLOOM-EDITION-_M but i would go with this one instead its a bit easyier to get http://www.tradebit.com/filedetail.php/26965882-elna-6005-sewing-manual-instruction-manual if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 15, 2010
Tally Girl
  • 1133 Answers
SOURCE: I need an instruction manual for the Elna Carina
There is a sewing guide available free here for the SU which is very similar to the Carina
http://www.arizonaexpressionz.com/elna_instruction_manuals/SU_air_electronic.pdf
but not an instruction Manual.
The SU, Carina, 500 and Jubilee all came with two books, instruction manual and sewing guide.
Posted on Jun 16, 2011
SOURCE: The flywheel on my elna special sewing machine won't tighten after winding on thread to the bobbin.
it's very possible that a part could be worn or jamed or even broken
only a sewing machine repair shop can tell what wrong
Posted on Feb 02, 2012
How do you thread an elnita 200 ?
How to thread and use Elna SU sewing machine
Athough most likely not your model, threading instructions are pretty much the same for the majority of machines except in extreme cases. Of course, a manual for your machine would also be helpful, even just for the maintenance and use instructions.
Elna Elnita 200
Elna 240
Instruction Manual Elna Elnita 200
Tip: ALWAYS RAISE the presser foot when threading the top thread. Always start out with a brand new needle (and change it at least every 8 hours of sewing time).
Dec 04, 2017 | Sewing Machines
How do i thread Elna 1200 also bobbin placement.
You should probably find an owners manual. Search for:
Make Model manual
(however, Elna manuals are seldom free)
IMPORTANT TIPS:
ALWAYS RAISE the presser foot when threading the top thread! Install a brand new needle at least every 8 hrs of sewing or whenever it strikes something. AVOID old and bargain bin threads.
How To Thread An Old Elna Sewing Machine
Elna Threading Instructions
Nov 17, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
I need an instruction manual for the Elna Carina Electronic sewing maching
Oct 25, 2010 | Elna Sewing Machines
Sewing Machines Logo
104 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
