<!-- from fixya rte -->What is the status of my refill order - Office Equipment & Supplies
I ordered a refill of Valsartan on-line on 17 April and have not heard any status to date. I only have 4 pills left
fixya is not an online pharmacy you need to notify your place of purchase for your request
Apr 26, 2017 | Cell Phones
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Trying to find out if order has been shipped and delivery status of package
Every website is having its own protocols through which they can able to know about the orders and shipping delivery. In most of the websites we can able to know about order details and shipping delivery from the email id you have given at the time of registration. Some websites are having a page of Order status, from where we can know about the delivery status of your order.
Know More:- Build Your Online Store
Apr 13, 2015 | Computers & Internet
How do i bring up the account for Thomas James with Express Scripts?
Go to express-scripts.com and create an online account. Then you can access your account online.
Sep 01, 2014 | Office Equipment & Supplies
Hello sir i want to know the details of cartridge if it shows the status " The Toner is exhausted replace the toner" is there any chance to refill that one or replace it please give reply.
It depends on the Model of the printer and cartridge number. You can't refill all the cartridges. If you let me know the model of your printer and the cartridge number, I think I can help you how to refill it and how to open it apart.
Thanks.
Aug 30, 2010 | Office Equipment & Supplies
I have installed refilled cartridge but since the time i have refilled the cartridge and installed it the printer is showing error e-5 what to do.buying a new cartridge each time would be a costly...
Canon MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Jun 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
After refilling the status show toner empty
refilling toner manually? check if toner grade same as required by that model? if toner cartridge new check for the tape on both side contact.
Mar 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I have a lexmark X3650 printer. I have refilled my black in cartridge. (Drilled the hole and refilled). The printer does not detect the refill and keeps telling me the cartridge is empty. Help please!!!
Unfortunately, the cartridge has an indicator that tells the printer what its status is. This doesn't get reset when you refill the cartridge. With some printers, you can use a few other new cartridges and then try the refilled one again. (These printers store the cartridges last used and status; but can't store a long list of "this cartridge was empty".)
I wish I could be of more help.
Mar 04, 2010 | Office Equipment & Supplies
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
35 people viewed this question
k24674
