Question about Exercise & Fitness
Hi is there a way to set my treadmill to set up I
Hi is there a way to set my treadmill to set up I only found two buttons I really want to use it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Need more info. Like make and model.
Posted on Nov 10, 2014
Will not come on. Has power to it. Is there a restart button? a fuse? What?
Hi Hannah.
The manual for this treadmill can be found here:
http://www.landice.com/sites/default/files/Landice_PST5_Manual%2372116_PDF%203-1-15.pdf
What stands out in these instructions is that there is a red, magnetic safety key that must be connected to the panel to run the treadmill (PDF page 4). Also there is a diagnostic mode covered on PDF page 19 that should let you find out if the treadmill thinks it has some other problem.
Hoping this helps
Good Luck
D
Nov 19, 2015 | Landice L7 LTd Pro Sports Trainer...
The start and stop button are stuck down
Hi Kellie, you didn't mention what brand of treadmill, but this is a common failure with Overlays, which can be found at online fitness stores like Sportsmith. You can also contact jatinah electronics for further help. Good Luck!
Jan 19, 2015 | Exercise & Fitness
When I put the key in, the treadmill belt goes really fast. Its like its stuck and I can't turn it down the knob keeps popping off. Do I need to get it serviced.
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run at high speed without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
Sep 04, 2011 | Weslo Cadence CT 4.8 Treadmill
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Will switch on but the enter button will not work and the other buttons will only work occassionally. we have a precour 9.21s
hi
check the push button (micro switch) for enter. may be it faulty. if found faulty replace it. its a cheaper one.
ok
Dec 26, 2010 | Precor 9.21 Treadmill
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
Console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Feb 14, 2009 | Proform 540ls Treadmill Walking Belt
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
