Question about Cameras
I've asked the same question twice bit it has nothing to do with camera. Just a general question
Camera is disabled on my Asus G75W?
DO a system to go back to a known good date. Go to start > programs > accessories > system tools > system restore. Select a date when the camera was still working great. Let the computer restart by itself to complete the restoration.
If no go, try going to safe mode: Restart the computer and tap F8 once you see the options to go to safe mode, use the arrow keys to highlight it. Press enter and try if your camera works inside of safe mode.
If your camera works in safe mode, then it's a software problem (specifically the driver). If all fails, I suggest that you install Radarsync and let it run so that it will automatically search for outdated drivers. It will update them all as well.
I hope this helps!
Carlo
Dec 18, 2012 | Computers & Internet
My wildgame camera model S4 will not power back up, I've changed the batteries twice and checked them with a volt meter to make sure they are good. I've only had the camera for 1yr.
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Oct 17, 2012 | Wildgame Innovations S4 Digital Camera
THIS SITE KEEPS POSTING ANSWERS THAT ARE TOTALLY UNRELATED TO MY QUESTION
Try posting your question in a more appropriate area of FixYa. From what I can tell, you're asking about a porch light timer of some type. You've posted twice in the "Cars & Trucks" area and three times in the "Digital Cameras" area. Your questions are seen by experts in those areas, none of whom may know anything about porch light timers.
Aug 29, 2012 | Cameras
How do you delete a question on FixYa if you realize you've asked it twice?
Currently there is no way to delete a question you have asked on FixYa.
May 08, 2012 | FixYa Service
I just used the camera twice and it doesn't open any more. i've changed batteries but nothing.what should i do? is there a place to send it?
Why wouldn't you bring it back to where you bought it? If the time since purchase is beyond the store's return policy - or if you can't determine where it needs to be sent; they should be able to provide all the information you need to return it.
Oct 13, 2011 | Cameras
Weber Genesis with a low flame! I've replaced the reglator twice and each time it works for a bit then the flame goes down to almost nothing. There seems to be screen protecting where the...
if you can take the burner out and try blowing air down it see if this clears , check injector is not block, check gas line is not blocked , or try new burner
Sep 05, 2011 | Weber Genesis Silver B Grill
Kodak EasyShare M320 lence cover cracked a bit when it fell down how much will it generally cost 2 repair & is it possible 2 repair...
All you need to do is to contact kodak at 1 800 235 6325 ext 12. You may ask also about the total repair cost of the camera or avail their service upgrade program. Dont worry about the camera kodak can fix it.
Nov 20, 2009 | Kodak EasyShare M320 Digital Camera
Vivitar
be sure that nothing film inside the camera , open back side of camera by pulling spinning knob , put film spool on left side and at the right side insert the film strip on diagonal small hook, turn the spool rachet turning left side then click shutter twice while holding the spinning spool left side , then close the cover , tightened the spinning spool little bit then test shoot.
Dec 25, 2007 | Photography
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
