Question about Saeco Solis "Master 5000" Fully Automatic Espresso& Coffee Center
After DESCALING and pressing ent key OVERTEMPERATURE appears instead of LANGUAGE
  • Marica Hefti
    Marica Hefti Nov 10, 2014
    It now says DECALCIFY READY FOR USE. i.e. I can brew coffe but the DECALCIFY signal remains.
    Habit-Forming:
  • Saeco Expert
  • 147 Answers
You just have to prime the machine.Rinse some water from knob.
Posted on Nov 26, 2014
My cd/dvd produplicator is now only burning cds and not dvds. I am getting error message that says target drive not ready. Is there a solution or must I replace the target drive altogether?
You can try going to manufacturer's website to see if there is a firmware update. You can try uninstalling a reinstalling the application/drivers for the device as well.
Jun 01, 2014 | Vinpower Digital Computers & Internet
My @ key isnt working. instead of that the other blue marked colan is coming. how to toggle back
Have you tried pressing the button "2" on your laptop? And have you tried pressing "Shift" and then "2"? If the number appears when pressing 2, but @ doesn't appear when pressing "Shift" and then "2", chances are your input language aren't correct. Go to Start > Control Panel > Regional and Language Options > Languages Tab. There you can set the proper input language for your keyboard.
Try using the on-screen keyboard as well. Go to Start > All Programs > Accessories > Accessibility > On-Screen Keyboard. If @ works there, then its possible your keyboard might be faulty.
Jan 30, 2013 | HP Pavilion dv6-1030us Notebook
M disc duplicator not recognized by computer
The duplicator has a usb option that needs to be selected via the duplicator controller menu. If your duplicator menu currently reads 1. Copy scroll up using the up arrow key to look for the Usb Mode. You may be prompt to switch to the Usb Mode by pressing Ent. Once you do so the duplicator will reboot and the drive should be available through the (My) Computer screen on your personal computer. If you do not see the Usb Menu option on your duplicator menu you can turn it on by holding down the ESC until you hear a beep. It will display the Adv Setup Menu. Scroll down until you see "Usb Option", press the ENT then scroll down to select the ON position and press ENT. After the Usb Option has been turned on you should press the ESC button twice then scroll up until you see the USB Option, press ENT to view the option then select to turn in ON and press ENT. Feel Free to give us a call if you have further inquiries.
Tech Support - Johnny
Produplicator
866-817-4094
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Nov 29, 2012 | M-Disc Disc Duplicator - 1 Target
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Just bought it... overtemperature keeps coming on. Is it screwed?
maybe not; this will happen if you press the blue button or press the ent button twice. otherwise, yes.
Sep 03, 2010 | Solis Master 5000 Espresso Machine
I changed the language and can't get it back to English. Can someone tell me how please????
I suggest you go to www.hp.com/support and search your 3380 printer. Find the owners manual and look in the index for instructions on how to change the language. If you have the owners manual ... well you could use that instead.
Mar 08, 2010 | HP LaserJet 3380 All-In-One Printer
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Descaling problem
make sure the * is on the descaling line
Jan 25, 2009 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
122 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
