Computers & Internet Logo
C
C BEDDOW Posted on Nov 08, 2014
HOW DO I ROTATE MY SCREEN USING SHORTCUT KEYS?
manzanoalvin
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Nov 09, 2014
manzanoalvin
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
734
Points
23
It depends on what video driver you have. But you can try CTRL+ arrow key; or CTRL+ALT+arrow key.
Stjepan Gudelj
Level 1:
New Friend:
  • Contributor 2 Answers
Stjepan Gudelj
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1256
Points
CTRL+Shift+ [Up,Down, Left or Right] (Cursor keys)
How do i make the screen rotate again?
What OS is running? If Windows, there may be a shortcut or Fn key that changes the orientation. Look in the Notification area of the Taskbar for a Display or Graphics icon that will let you rotate the screen to Landscape or Portrait view. It might be as simple as Alt/R or Fn button with a F1 through F12 key with an icon that looks like a rotating screen.
tip
Key Shortcut for rotating screen
There have been a few posts about some peoples screens randomly rotating and there is generally two ways to fix it. One is by your graphics properties but a much easier way (and which is how it occurs during some game play) by pushing CTRL, ALT and a directional key all at once. Each key will change to it's own direction.<br /><br />As CTRL and ALT are heavily used in games some people may experience this.<br /><br />Thanks.
on Nov 28, 2010 • Computers & Internet
tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 • Cell Phones
Dell Inspiron N5110 screen rotated how do I get it back to normal
That is a software setting. You probably accidentally hit a shortcut key that rotates the screen.
Go to the graphics options (right click on the desktop/wallpaper), there is probably a rotation option (tab). Set the rotation to normal (0 degrees).
Gateway laptop computer screen is upside down and can not use mouse
Shortcut Key To Flip The Screen In the Windows TO 180 Degree..
The shortcut is (or should be, read below**)
for normal windows : Ctrl + Alt + <Up arrow> (or shift+alt+<up arrow>)
and for 180 deg it is : Ctrl + Alt + <Down arrow> (or shift+alt+<down arrow>)
However, you should know that these are default shortcuts for
Intel Extreme Graphics Controller, and you can change them. To
check / change or disable these keys go to control panel->Intel Extreme Graphics->Hot Keys.
**sometimes the shortcuts do not work. This happens when you have not enabled rotation
feature in Display Settings under Intel Graphics Media Accelerator media. You need to
enable rotation in order to be able to Rotate / Flip your windows screen upside down / 90 / 180 / 270 degrees.
Mouse: with mouse, do you mean a usb mouse or the mousepad? if the mousepad isnt working, check ur "F" keys for an icon that looks like a mousepad icon. Then press the "Fn" key + the corresponding mousepad icon key and see if it works.
How do i turn my screen back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
3helpful
My screen is on sideways and i cant put it back the right way
Tips & Warnings
1helpful
12helpful
2answers
Screen image rotated through 90 deg.
Hello , friend
Please do this shortcut
ctrl + alt + arrow keys
3helpful
Tablet pc rotation
u can use once time alt+ctrl+ any type arrow to roated screen
Grand Canyon Tech
Grand Canyon Tech
