Question about Home Security
Turn off tamper on gardtec 350 so I can fix socket
I need to programme the alarm panel so I can switch off the power without the alarm sounding
  • peter_burns2 Nov 10, 2014
    house intruder alarm. When I turn off mains power the alarm is activated. I need to switch off alarm while I work on house electrics. The question is how ??
    Problem Solver:
  • 5 Answers
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Posted on Mar 28, 2015
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
Parking lights start blinking...won t stop until you disconnect battary or start and shut it off and that last for a little while can any one help with my problem.....thanks
This sounds like an Alarm issue. If you had an alarm added to the vehicle after it was purchased you need to deactivate that by removing the power wire or fuse in the power wire. if that vehicle has the alarm built into the PCM, the vehicle computer, it may just need to be flashed. If neither of those turn out to be the problem the next place to look is the light switch itself or if you have added a device that was wired into the fuse panel for power double check the fuse panel for a lose wire making contact on occasion.
Jul 03, 2011 | 1997 Dodge Caravan
Alarm is armed, and I dont have a remote.I need to manually dissarm the alarm or my car will not start
Open the door, the alarm will sound , go under your dash, normally installation techs will install a kill switch or alarm override button either in the drivers side kick panel to the left of were your left foot rests or inside the fuse box panel, under the steering column or by the center column somewhere but most likely the drivers kick is the spot. So open the door and find the kill switch or override button and put the key in the ignition turn it to the on position without cranking and press or toggle the switch after you turn the key, this should override the alarm and let you start the vehicle, otherwise you have to remove the alarm main fuse from the brain and rewire your starter kill to factory so that you can start your vehicle normally again until an alarm tech corrects the alarm wiring.
Good luck my friend, hope it is helpful.
Jun 12, 2010 | 2002 Oldsmobile Alero
Hyundai tucson 2007 rear door wont open, alarm switch, power switch and key will open all doors except rear.
Sounds like the acutator that pushes and pulls. either lost power or died. I would assumed died. U need to check to see if it is on a seperate fuse first, it may be. If the fuse is ok, remove the hatch inside plastic panel and arm and disarm the alarm. See if the actuator moves.
Dec 08, 2009 | 2005 Hyundai Tucson
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
How to set factory alarm without remote, togle switch enabled
factory alarms are passive, if it is working it sets itself when u exit the car. u don't need the remote for the alarm to work if it has a factory system. if u want to test if it is working lock the car with the power lock button and leave the window down, reach inside the car and open the door from the inside handle, the alarm will sound if it is working, to disarm just lock and unlock driver door with the key..
May 31, 2009 | 1993 Nissan Pathfinder
Home Security Logo
906 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
