Question about Electronics - Others
Is Clear-Cast TV micro antenna for free TV access a legitimate thing?
    Sergeant:
  • 216 Answers
The advent of HD TV has allowed for a new round of hucksterism to occur in the TV antenna industry. The televison channel spectrum is the same as it always was but the signal modulation scheme employed now is "digital", which is for the better. Signal propagation is the same as it was and it is not necessary to buy a "digital" TV antenna unless you fidn it necessary to receive TV channels that have sprung up from new directions. VHF and UHF TV signals travel in straight lines and are the strongest when your receving antenna is "aimed" at the transmitter for that channel. Since transmitters are lcoarted all over the poalce, you can eoither use a mechanical antrenna rotator to position the antenna to aim the transmitter of choi ce or use multiple antennas aimed in various directions.
Genrally speaking, the "cheaper" antennas have fewer elements and are thereby less critical to aim. They have a broader beamwidth, so-to-speak, provideing less "gain" in a specific direction in favor or a larger average gain over a broader "angular displacement.
Digital TV signals are not prone to "ghosting" so an array of cheap antennas aimed in several directions will suffice to capture the digital TV signals in your local area. Amplifed antennas are poor substitutes for "real" (passive) antennas placed in attics or as high as possible outside. TV signals are blocked or absorbed by buildings, trees, and such and the signal intensity can vary with the weather and even when leaves are on the trees and when they are not. All your digital TV requires is enough signal in order to work. A small amplified antenna sitting atop your TV may work fine though the signasl is barely above the minimum threshold. When the weather grow wetter, that singal may be beleow threshold and you won't get that particular channel until there is less moisture in the air!
The same is ture, of course, for an antenna placed high up on the roof, but the odds are far better that it will work so much better than the tiny amplified antenna on the top of the television simply becaeu the TV suingal inside the house, at lower elevation, will be inherently weaker to begin with.
Hope this helps you decide.
Posted on Jan 19, 2015
    Master:
  • 426 Answers
Over the Air TV is free! Go to TVFOOL and put in your address and it will tell you what type of antenna and what stations you can get. Click on this link. Any Micro antenna would require that you are pretty close to the TV transmitter.
http://www.tvfool.com/?option=com_wrapper&Itemid=29
Posted on Nov 18, 2014
Purchased a venturer tc to
Which is the name for the antenna in the manual?
Apr 06, 2008 | Televison & Video
How do I connect a Lenovo tab a2 10-30 to a tv hdmi socket?
You cant. It does not support any video out. The o ly thing you can do is cast the tablet to something like a roku, chrome cast, etc
Aug 25, 2016 | Lenovo Tablets & eReaders
Is Clear-Cast TV micro antenna device legitimate?
From a basic standpoint, yes it is legitimate and it will work. How well it will work really depends on a number of things. it depends on where in your house you place it, how far you are from the transmitters and what your house is made from. The structure can interfere with reception.
As a general rule, outside is better than inside for over the air digital reception. Higher is also better, so place any antenna as far up on your house as you can outside, next go to the attic space if you can;t mount it outside. And even if you are in a condo or HOA , they have to allow you to mount a TV antenna on your house outside under FCC regulations.
Nov 08, 2014 | Televison & Video
With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the...
Hello
You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
Mar 27, 2011 | Televison & Video
MyCB radio wont broad cast
One of two things is wrong---either a problem in the radio or a problem with the Microphone----
Do you know how to open the mic plug and check the wires there?
Most of the time it is a problem with the mic cord---
Let me know if you need wiring diagram of the Mic--I can provide that---almost any 4 wire mic can be used to replace the stock one---
Original mic was 1 k impedance---but a 500 ohm mic will work and make the audio even louder.
Also have someone check the SWR or match on the antenna system--easy to do.
I am here to help---if this helped you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Unclear TV pictures
Well what your problem is the antenna is not secured well enough to the roof. You really only have a couple options, you can secure the antenna better or just live with the fact that when it is windy your channels will be fuzzy.
May 11, 2008 | Televison & Video
Electronics - Others Logo
398 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
