Question about Pool & Spa
I just rebuilt my flowtec fpof 360ac pump with a new impeller, seals, etc. because it wasn't pumping water. The rebuild didn't fix the problem. There is still almost no pressure in or out when I tur
I just rebuilt my flowtec fpof 360ac pump with a new impeller, seals, etc. because it wasn't pumping water. The rebuild didn't fix the problem. There is still almost no pressure in or out when I turn it on but the pump is turning???
  • 2,509 Answers
If you have replaced the impeller and seals there must be an air leak or blocked hose somewhere - perhaps on the inlet seal?
http://www.flotecpump.com/resources/images/517.pdf
Posted on Nov 08, 2014
  • 11 Answers
SOURCE: pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Posted on Jan 03, 2009
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
PartsCenter
  • 125 Answers
SOURCE: Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
john224
  • 1378 Answers
SOURCE: Softub about 4 years old - I have a leaking water
Thank you for posting your question here on Fixya.com.
Neither...it is threaded onto the motor shaft. Lock the shaft at the end opposite the impeller and turn it off counter clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 13, 2010
Testimonial: "Thanks John - very helpful"
Re Installed a rebuilt pump and now the pump starts surging once I open up the flow to the max. Previously it did not.
I think an air leak into the suction side, or with the new-found power of a tight impeller, the water level in the skimmer box is a bit low.
Check all joints, especially the rubber bellows which is usually on the suction side of the pump basket, and the seal on top of that basket.
Mar 06, 2015 | Pool & Spa
RKV4G36 will not pump water. The "expert" that was using it says it needs to be rebuilt. About 3-4yrs. old with maybe 100 hours on it. Was told he started it w/o water turned on. Rebuild? New...
Bad news if he ran it without water he may have damaged the seals inside. If you screw in your water hose and water immediatly leaks from pump head then those seals need to be replaced they cost about $75. If its an RKV pump they are very resiliant and expensive they are usually worth rebuilding.
May 06, 2011 | Annovi Reverberi RMV2.5G27D Pressure...
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
Im getting a loud buzzing noise when the pump is running
could be an obstruction in the impeller, or the bearings going out. You can split the pump in two be removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing. once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Now you can easily try and spin the impeller and check for obstructions that might have bound it. If you do not see anything stuck in the impeller, then the noise is likely coming from the motor (probably the bearings) you can replace the motor, or have it rebuilt. if your not gunna rebuild it you can deal with it as long as the noise doesn't bother you and the motor is not getting too hot
Sep 15, 2010 | ADVANTAGE Waterway SVL56 Pool Pump...
1 HP StaRite Pump 15" inout Center Discharge 240V wHair Lint Pot: Impellers on pump wont turn. Motor not running...
what happens is the pump gets staved for water and this damages the shaft seal, water slowly over time leaks into the motor and pollutes the grease int the bearing and causes it to fail. it's fairly easy fix, just have the motor rebuilt by your local pool pump motor repair guy for about 75.00 and your back up and running. beats paying 200.00 or more for a new motor.
the sta rite is the top of the line pump, i have had them in my shop over 40 years old ! ask your motor repair guy how to get the most life out of your pump. knowledge is king .. remember to prime the pump after any pump repair !! .. jay longwood florida
May 17, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
Model W1800 stop pumping after less than 6mos makes lots of noise and just a little discharge
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Mar 09, 2010 | Beckett Water Gardening Garden
Electric motor runs but water pump does not pump water.
Mar 09, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
On my way to work my tempo overheated and shut down. could this be the thermostat or water pump
check for water flow in the radiator. if the hoses dont expand when you rev the engine, the water pump is probably bad. alot of the factory water pumps have a plastic impeller on them, and the impeller will break in pieces inside the pump housing. if you take the hose off the pump you can see the impeller. napa sells a new one with a aluminum impeller and its a new one, not rebuilt.
Jul 17, 2009 | 1991 Ford Tempo 4 Door
Rebuild kit for the Aquascape SFA3000 Pump???
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Aquascape 4500 not working
Typical with these pumps, pumps I have rebuilt that have done the same thing what happens is the bearings get loos and cocks the armature that is why it won't spin. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Apr 25, 2009 | RTO AquaScape 4500 GPH Pump
Pool & Spa Logo
59 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
