Re-Gardtec 350. I need to turn off the mains power without the alarm sounding.
I need to resite a 13amp power socket & need to turn off power supply, The alarm activates when I switch off
  • 39 Answers
Unplug the battery first
Posted on Nov 25, 2014
HOW DO I REMOVE THE GARDTEC 300
remove the power from your alarm main box and battery if there is one.
Jan 10, 2015 | Home Security
Turn off tamper on gardtec 350 so I can fix socket
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Nov 08, 2014 | Home Security
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
Gardtec alarm 360/580 has gone off and i have no led display on the control panel. Can anyone help please
Yes, There is an answer you should have another Box somewhere under the stairs cupboard, most likely a dialer.
There is a rechargable) battery in there (Life Span 10 Years) which has ceased - you need to replace the battery and all is well.
Sandy
May 21, 2010 | Home Security
My gardtec ace home alarm external bell box wont
I'm not familiar with your particular alarm bell but most of the ones I've worked on have a dot on the gong that should be aligned with where the strike hits the gong. This is the "sweet spot" where the bell sounds the loudest. Another possibility is the gong may have loosened up and needs to be tightened or there is debris in there that needs to be cleaned out. I have found that bees and hornets love to build their homes inside of these boxes.
Mar 02, 2010 | Kjb Security Sn1 Telespy, Portable...
Will not charge or turn on or anything
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 4 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | ASUS Eee 4G Notebook
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
My pc is not turning on Asus p5vd2-mx se
what kind of computer is it? how old is it? have you added, removed or changed hardware recently? have there been any power spikes, outages or surges lately while the computer was running? lastly are the voltage settings 120V/240V on the power supply set correctly? it sounds like the power supply is dead from what i've read but i can't be sure because there are many reasons this could be happening, i.e. the processor gets too hot while the system is trying to start and the computer shuts down to prevent damage to it, also have you tried plugin the system into another wall outlet or socket on your power strip? if no hardware has been add, removed or changed. you can start with a power supply but if after that it still won't power up there's a deeper cause to look for!
hope this helps
Nov 23, 2008 | ASUS P5VD2-MX SE Motherboard
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
