Question about Sanyo DP26649 26 in. TV
My HDMI port 1 will not work tv says no signal is found. can I fix this are is it under warranty are recall.
HDMI 1 when I plug my blue ray will not work TV says no single
    Problem Solver:
  • 7 Answers
Most likely bad HDMI cable. I know they look fine as the day you bought them but it is a good possibility.
Posted on Nov 08, 2014
5 Suggested Answers
SOURCE: trying to connect hdmi cable to laptop to watch movies
Are you sure you have four hdmi ports? I have only one hdmi port and three usb ports. Be sure you are connected to the hdmi port and for some reason not a usb port.
Posted on Aug 17, 2012
  • 1702 Answers
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
SOURCE: computer has vga port and tv has hdmi port
Please know that VGA is an analog signal and HDMI is digital so it is impossible to go from one to the other without a converter. If you need to convert any VGA or component signal into a digital high definition HDMI signal up to 720p resolution, this conversion box will do the job perfectly. The only additional thing that you need to get besides this converter is an HDMI cable of the appropriate length.http://sewelldirect.com/Component-VGA-to-HDMI-Scaler-720p.asp Hope this Helps you!
Posted on Jun 16, 2012
SOURCE: When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
Posted on Oct 09, 2012
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
46 inch Sony Bravia TV is 5 years old. HDMI ports 1,4 work fine but 2,3 don't.
I presume you've checked that the HDMI cables are good, and that the signal sources (e.g., blu-ray player, Roku, etc.) are working correctly. If the HDMI ports are individually selected by four buttons on your Sony remote, which is unlikely, it's possibly a problem in that remote. It's also possible that ports 2 and 3 are physically damaged by abuse. If you have ruled out all of those potential causes, this is almost certainly a problem in the way the defective ports are attached to the underlying printed circuit board inside the TV, or a flaw in that PCB. Too bad it's out of warranty. Repairing this will be a hassle if it can be done at all, and probably not cost effective. Instead, I suggest three possible workarounds for your consideration.
First, if you can find another way to get the signals into your TV, such as using the component inputs instead of HDMI, that will your cheapest and easiest alternative. This will only be doable if the signal source offers other types of outputs besides HDMI. Note that I am NOT suggesting adding any type of signal converter, just a different way of connecting the signal source to the TV.
A second alternative is to buy a multi-port HDMI switch with a remote control which you can find for less than $30 at online retailers like ebay. Plug that switch into one of your two good HDMI ports, and connect your unserved signal sources to the switch. It will be slightly less convenient to use the multi-port switch because you will need to operate one more remote control than you do now.
The third possible workaround is to buy an autosensing HDMI switch instead of the multi-port type, which would eliminate the need for the extra remote. However, an autosensing switch must have only one signal source active at any given time. This may not be possible if one of your signal sources is a streaming device that is continuously powered up. Good luck!
Mar 01, 2015 | Sony Televison & Video
My blue ray / dvd player surround sound won't stay on when I have it on AUX for the TV. Model # SA-BTT195 (?)
What do you have plugged into the AUX port?
Have you tried HDMI 2 some tvs have a smart link on HDMI 1 that auto wakes the component connected to it but I dont know your situation.
Sep 20, 2014 | Panasonic Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia...
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
HDMI problems with 40'' bravia
The HDMI reciever board in the TV is bad and will need to be replaced. You should have a technician look at it so they can get the correct part number using the model number and the TV's serial number too.
Nov 11, 2009 | Televison & Video
RCA LCD 42Lfhd37 Unusable signal
have you tried calling to the store you purchased it from and seeing if they will print you a new receipt. alot of stores will do this for you. also some times the store will cover the tv under manufacturers warranty and will send someone out to your house.
hope this help
please feel free to ask if you have any other questions.
Apr 06, 2009 | RCA L42FHD37 42 in. LCD HDTV
Sanyo DP26649 26 in. TV Logo
224 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
