Where can I find a firing insulator? Part number 0026-3
  • 3,506 Answers
What make and model, the google it
Posted on Nov 09, 2014
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
May 16, 2017 | Kenmore Dryers
Who's number is 559 650 0026 I keep getting a call from thus number
MCImetro Access Transmission Services Landline in Fresno, CA Listed as a probable scammer
Dec 05, 2014 | Office Equipment & Supplies
2003 TRACTOR 4X4 WAGON IS MIS FIRING ON CYLINDER TWO
Try to see if you can get view the are where the plugs are firing in the dark. Check for arcing off the plug or wires to the metal engine parts. I fought with a vehicle for days trying to determine a misfire problem on a car that we just put new plugs, wires, and coils on. Turns out the ceramic insulator on one of the BRAND NEW plugs had a hairline crack down the length of the insulator. You could not see if with the naked eye, but you could feel it if you ran your finger over it. Easiest to find if you can run the engine in a dark garage.
Nov 24, 2012 | Chevrolet Tracker Cars & Trucks
How much clearance do i need to leave on top of the water heater between the insulation and the chimmney? is the insulation fireproof?
Gas or electric?
1) Electric heater can be completely covered with insulation except TP valve. Set electric heater on insulated surface. Insulate pipes completely right down to tank.
2) Gas heater is different.
No insulation over combustion area, or gas valve, or air inlet or. No insulation on top of tank that will interfere with venting of dangerous combustion products including odorless CO gas. Foam insulation on pipes should stop 10" short of tank top. No insulation within 6" of the 3-4" inch galvanized vent pipe.
Here's photo with gas water heater insulation tips:
http://waterheatertimer.org/images/Insulate-gas-water-heater.jpg
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
3) Tankless gas. No insulation on box. No pipe insulation within 12". No insulation near vent pipe.
4) How much clearance between heater and chimney?? Not sure what that means. Is that the water heater vent stack? Or where vent stack goes into chimney stack? No insulation on gas flue pipes. Or within 6 inches of 3-4" water heater vent pipes
5) Is insulation fireproof? Everything burns if it's hot enough. If you throw insulation into backyard fire, paper and foil will burn away and insulation kind of falls apart in the heat. Fiberglass insulation cannot be set on fire with a match. Foam pipe insulation will burn.
Dec 02, 2010 | Thermwell Water Heater Blanket
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
