Question about Android Apps
How do I get gems
I need gems to get some stuff and upgrade town hall and other stuff like that and to get some coins and elixir
Get rid of your trees gem box or stones
Posted on Nov 10, 2014
I need 1ooooooo gems on clash of clans please
this is fixya not associated with clash of clans try a gaming blog for the game your requesting
Dec 20, 2016 | Cars & Trucks
Stone are freed NO SURVEY by battle of kin?
Gems that are free are not really given by none of the websites. They're just scams to make an effort to get your cash or get a virus is downloaded by you. Regardless of the clash of clans hack tool clash of clans cheat they state, it's a scam. You should find out the best way to signal in the event that you want to crack, however I wouldn't propose doing that because coughing is PROHIBITED! DO ACTUALLY CHECK IT OUT!
Clash of Clans Hack Gems and Elixir Cheats in COC
Mar 31, 2015 | Computers & Internet
How do I get coc gems
U can donwload what videos shows
Mar 01, 2015 | Android Apps
96 ford exsplorer 4wd blinking lights
If after driving a little bit the 4wd light starts blinking then I believe one (or both) of your HALL sensors are bad or have picked up some metal filings.
I believe the light is blinking because your GEM computer doesn't think both driveshafts are going the same speed.
I think one of your HALL sensors is fooling the GEM into thinking one of the driveshafts is stopped all the time
When you are stopped the computer thinks everything is OK (because the other driveshaft is stopped also)
When you are moving the GEM tries to get both driveshaft spinning the same speed but the sensor isn't responding
It takes 5 minutes to change the rear sensor (you have to cut the old one off and splice in the new one. Sealing the splice with liquid electrical tape)
The front sensor is hardr becasue you have to remove the shift motor on the transfer case
also for the 4wd system there is a TOD(torque on demand relay) that might be bad
Jan 22, 2015 | 1996 Ford Explorer
Clash of clans
You should consider posting in the correct area!
Jul 21, 2014 | Gem Sound Audio Players & Recorders
I was playing Pet story, collecting my coins and accidentally spent 19 of my gems. I have an Android phone. My coins were too close to the nursery, as I collect the coins it actually pop got to pay to...
If I am reading this correct, what you are saying is that while playing the game you accidentally used 19 of your gems for something you never meant to do. If you, sorry they will not replace them, these are gem traps, I have lost hundreds of gems in these traps and there is nothing you can do. I play Restaurant, Bakery, and Fashion Story. If this is no help, sorry i read the problem wrong.
May 06, 2014 | Cell Phones
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
Clashcheat blinkweb com
I need alot of gems and alot more gold
May 12, 2013 | Computers & Internet
PHP Give me Cheat on Backyard Monster pls!..... T_T
the entire thing from 1 end to the other is engineered to try to frustrate you to spending real money on everything from "speed ups" to "protection". It's excruciatingly slow & resource hogging upgrades to 1,000 Shiny for the 4th worker & then an unannounced doubling of that to 2000 Shiny for the 5th worker. So if you are not used to this kind of gaming chicanery, you might, say, go buy or save 2k Shiny (I bought $20 worth of Shiny (3000) and inadvertently spent all of it on the 2 blue dots called "workers" because of this bait and switch tactic). Another tidbit buried in BYM's forums is the little gem that people cannot attack you while you are there! They have to attack you behind your back when you are not logged on! Oh but wait! Then can you or does it make automatic (free) repairs for you while you are away? Why of course not! If you are expecting reasonable fairness in this game, forget it! While you can be attacked up to 4 times an hour, any repairs have to wait until you come back and click on the "repair" button, which in my case last time was 7 hours after 2 attacks! Then of course, the higher the level of the resource, the long it takes to repair them, in my case 45 minutes for each tower. Yet another tidbit buried in the forums: This one concerns town hall level 6. if you save the 1.7 miliion in resources to do this upgrade, which takes 4 days (Buy our shiny to speed it up now, y'hear!) and do it because you want more weapons and a significant amount of more blocks to build walls and 10 more mines that you've been getting with previous town hall upgrades, forget it, this is a bogus upgrade. All you get for your effort is 5 more mines, 10 more stone blocks and the ablitity to upgrade each silo to level 10.
Feb 08, 2011 | Video Game Consoles & Games
Android Apps Logo
83 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
