Question about Garden
I have a craftsman lawn sweeper 32 inch pulling it forward the wheels slides
  • Bill Cenne
    Bill Cenne Sep 09, 2017
    This usually means the brushes are contacting the ground. They need to be set a few inches "OFF" the ground. Never use a lawn sweeper to "dig" the leaves out of the grass. Dethatch the lawn first, then try "sweeping".
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
  1. The sweeper wheels or axle (if live axle) need servicing and lubing if they do not turn freely.
  2. If the sweeper from end rides too low, the sweeper will essentially be dragging, possibly with wheels elevated slightly out of contact with ground. Remember, the ground is what turns the wheels. One way would be to raise sweeper hitch tongue by inserting washers between tongue and mower hitch.
  3. If all check, adjustment, and lubing does not correct, consider putting weight on the seeeper or in the sweeper collector to put more weight on wheel contact with ground.
Posted on Nov 10, 2014
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
GM Elec
  • 1000 Answers
SOURCE: Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Posted on Jun 12, 2009
SOURCE: rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
Posted on May 29, 2010
  • 420 Answers
SOURCE: Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Posted on Jun 04, 2010
  • 19 Answers
SOURCE: Problem for Craftsman 20 hp 42 in. Deck Lawn Tract...
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
Posted on Aug 09, 2010
Why is the forward engine pulley so hard to turn on my Craftsman 42" Model No. 247.288812 lawn tractor?
Are you talking about the Engagement pully? Item 24?
http://www.manualslib.com/manual/518759/Craftsman-247-288812.html?page=32#manual
If so, the reason it is hard to turn is because it is attached to the shaft of the engine and also has the pully for the wheel drive attached to the same shaft.
Jul 02, 2014 | Craftsman Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Looking for manual for a Craftsman lanw sweeper
You can go to www.searspartsdirect.com and download a manual for it to either save to your computer or print it out or both
Sep 26, 2009 | Craftsman Garden
Trans dose not work since i replaced rear tire on lt 1000 tractor
Similar thing happened to me . There is a half moon "key" that slides into a groove in the axle. Sounds like that fell out when you took off the wheel. Look around where you took the wheel off to see if you can find it. If not they're not very expensive at a repair shop. I did not know this & I took in in to the shop. Luckily they only charged me for the part.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
255 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
