Question about Acer Aspire 3810T 4810T 5810T
My battery will not charge. Have tried different batteries and chargers. Works fine on mains power. Any ideas please? Roger
It just stopped charging suddenly. It does run on both battery and mains power. it says it is charging but it isn't.
    Habit-Forming:
  • 157 Answers
Sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Posted on Nov 09, 2014
Testimonial: "Thank you, but it didn't work for me."
4 Suggested Answers
  • 79 Answers
SOURCE: My battery is not charging. I bought my Acer 5738g
Remove battery, replace and ensure contacts are clean. If wont charge then battery is dead. Get a new battery.
Posted on Dec 20, 2009
  • 345 Answers
SOURCE: I just replaced my laptop
try putting the old battery back in and see if you get the same problem. Also check where the chargers plug goes into the laptop. If it fits loosely your charger port needs replacing.
Posted on Apr 02, 2011
  • 4961 Answers
SOURCE: there is no power going into acer notebook, have replaced charger but still nothing happenen when plugged in the charger light does not go on what can i try?
Then your motherboard probably needs to be replaced.
Posted on Jul 01, 2012
Why is it not charging?
1 Battery no longer holds a charge
2 Charger is faulty
33 Charger circuit does not function
This is assuming the mains socket works ok
Try a different charger, if that does not do the trick you know it is either batteries or charging circuit. Then change batteries, if that does not work you know it is a charging circuit fault
Jun 11, 2015 | Tablets & eReaders
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
I can´t switch my camera on and i also can´t recharge the battry throw usb
The camera doesn't charge though the camera is on. It only charges when the camera is off. Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak V803 Digital Camera
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
I cant charg my psp i cant find my charger
When you say you can't cahrge it, do you mean on your PC, PS3 or with the charger? I don't think the PS3 charges the PSP, I have no idea about the PC, but if the PSP doesn't charge using it's charger, it is either the battery, the charger, or the psp charger outlet. If it is the battery, buy a new one. If it is the charger outlet, it is a good idea to have 2 working batteries and to buy an external charger at game crazy, game stop, or from sony. This way, you can switch out batteries while playing, like me :). If it is the charger, buy a new one.
I would suggest first trying to buy a new battery. If it works, you are good to go and your old battery was broken, otherwise your charger/ charger outlet is broken. Buy an external charger. Then, you will be able to charge the batteries while one is in the PSP.
A new battery and an external charger cost about $70, but it is worth it. I hope i helped.
Sep 05, 2009 | Sony PlayStation Portable (PSP) Console
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Aug 20, 2008 | Dewalt DC011 AM/FM Radio
My Nokia 2310 suddenly switched off. It didnt switch on again. I tried putting the battery(of problem phone) into another cellphone, the battery works fine. I tried to charge the problem phone, but is not...
I tried to charge the problem phone, but is not showing any activity upon inserting the charger jack. Other phones are getting charged using the same charger.
Any idea of what the problem could be?
Jul 29, 2008 | Nokia 2310 Cellular Phone
Camera won't charge
If your camera appears to be in working order, your charger or the power outlet may have an issue.
With all connections intact,
1) Please try to connect the charger to a different power outlet and try again.
2) If the charger doesn't appear to show any indications of charging, try with a different charger.
3) If the charger works fine, there may be something wrong with the battery - or the camera. In such a case, please consult an authorised service center for a resolution.
Thanks!
Jul 19, 2008 | Sanyo Cameras
Acer Aspire 3810T 4810T 5810T Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
