Question about Bernina Sewing Machines
I have a bernina 750 that won't turn on it's only 3 months old and I've tried multiple outlets I'm the house
    New Friend:
  • 36 Answers
Lol sry. Check the cord at the machine, not the outlet in the house. Loose plug, maybe?
Posted on Nov 09, 2014
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Why would my Bernina 880, 10 months old, not boot up?
While the surge protector is an excellent thing to use, BERNINA sewing machines also have a set of fuses in the power supply. There is a chance that one of these fuses has blown. My recommendation would be to take your machine into your local BERNINA dealer to get it checked out. As long as you have checked the cord, the surge protector, changed plugs on both, and checked the circuit breaker in the house, it is probably an internal issue that is best fixed by a certified BERNINA technician.
You can find a nearby dealer, at the enclosed link or go to the store where you purchased your machine.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Nov 02, 2015 | Bernina Sewing Machines
Bernina 750 won't turn on tried multiple outlets still nothing
Could be a faulty on/off switch or worse, the motor could have burnt out. Bet to take it to a dealer and have it looked at.
Best wishes
Nov 08, 2014 | Bernina Sewing Machines
My Bernina Artista 180 won't turn on
here is a link for bernina, click on the link and it will take you to
the contact us part,, choose which option you need, maybe
technical support contact them ask them if there is a hidden
http://www.bernina.com/en-US/Company-us/Contact-us-1
Mar 29, 2013 | Bernina Artista 180
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Jan 23, 2013 | Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
Sewing Machines Logo
179 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
