Question about Kenmore Washing Machines
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
400 Series.My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than go to dryer sheets?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
The dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Posted on Nov 09, 2014
5 Suggested Answers
  • 530 Answers
SOURCE: clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Posted on Jan 11, 2009
  • 113 Answers
SOURCE: Spots on my clothes after washing.
the transmission seal may be going out leaking oil
Posted on Apr 24, 2009
hiltonjug
  • 612 Answers
SOURCE: how do i clean the fabric softener dispenser in my
If it's located at the top of the agitator. It pulls off. Pull straight up. After you have removed it. Run hot water through it. Take a old toothbrush and brush down inside it. You can use Mean Green to help cut the goo. Now rinse and shake over and over. Pop it back on.
Please rate solution
Posted on Aug 27, 2009
  • 6277 Answers
SOURCE: my fabric softener dispenser stays
One of two possible causes- the softener tray is blocked so the softener cannot siphon out when the water is fed into it OR the water is not being fed into the tray. It is relatively easy to check for the first so I advise checking that before calling for service.
Here are my general, pre-typed (!) guidance notes for cleaning the tray,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 12, 2011
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Does the fabric softener dispensar come apart?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7914776481dcf14414831964a8792e18
Depending on the model, your fabric softener may have a ring around its bottom. Push down or pull up the ring and the dispenser should pull straight up. It doesn't twist off.
Also see the following Sears site. It may have an on-line manual for your machine.
http://www.managemyhome.com/
Mar 20, 2010 | Kenmore 22422 Top Load Washer
Dual action kenmore 70 series washer need to remove agitator
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
How do i clean the fabric softener dispenser in my kenmore 80 series washer? Does it come apart to clean the inside? It is full of gunk and the fabric softener won't come out.
Aug 27, 2009 | Kenmore 24902 Top Load Washer
WHERE DO I PUT FABRIC SOFTNER
Hi, If there isn't a softener container in the top of the agitator, you can get a softener ball from your local grocery store. Just put the softener in before you wash and it will open to release the softener during the spin cycle. It works great. I use it all the time.
I hope this helps. Please let me know if I can assist you further
Vic
May 20, 2009 | Washing Machines
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore model 110.20932991
you should be able to remove the dispenper if not try putting vinegar into it and run the washer
Nov 06, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
