Question about HP Designjet Z6100 InkJet Printer
HP Z6100 error code 79:04
I had an error code 42:10, cleaned the slider rods w/papertowel and water like suggested now i recevie an new error code but cant find info on this one thanks
  • HP Master
  • 1,121 Answers
Generic Firmware error.
Check that the Printer has the latest Firmware version?(chek through control panel, configuration page, zet admin) If not, update the Firmware to the latest version. Down load FW from hp official web site, upload it as specified, if you not familiar to do so., take help with others or call technical professional. Any error while uploading will damages the farmatter..
Posted on Nov 09, 2014
  • HP Master
  • 1,915 Answers
79.04 is a system error like ablue screen in windows. The troubleshooting process is very complex. Your best first step would be to disconnect any data cables and restart. If the machine comes to ready then it may be that you are sending data with either a corrupted print job or the wrong driver. If it errors even with the data cable disconnected then you will probably need to reset the eeprom. Make sure that the formatter is seated properly and all components on the formatter are seated properly.
4 Suggested Answers
  • 96 Answers
SOURCE: HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Posted on Sep 28, 2009
  • 123 Answers
SOURCE: Error Code 08:11 HP z6100
The 08 portion of the code indicates FRONT PANEL. the :11 is an action code requesting RESEAT, CLEAN meaning you should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which can be downloaded here: www.lpscomputer.com/ec/manuals.htm
Posted on Apr 16, 2010
mishrajk21
  • 202 Answers
SOURCE: hp z6100 turns itself off!
it contains m/b like desktop with cpu,ram,hdd etc check ram cpu fan & power supply refix them after cleaning ...............may b ur problem will be resolved.
Posted on Jul 30, 2010
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Nov 26, 2014 | HP Designjet Z6100 InkJet Printer
Error code 43:10 on HP Z6100. What do I do to fix it?
This error indicates that the vacuum fan is stopped. 97412466-7fff-4e2d-bb4c-526bd4f30ed9.jpg
Oct 07, 2014 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 42:10
error code 42:10
Electrical fault in Carriage Motor or starting the Scan Axis or Homing Scan Axis.:
it is not uncommon to find that the encoder is the fault behind the error code,
in the User manual there is a procedure for Cleaning The Encoder Strip. you should follow these steps carefully
.A Z6100 User manaul is available to download at HP.com link as follows:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?cc=us&contentType=SupportManual&prodSeriesId=3338748
the user manual is located near the bottom of the page
Sep 25, 2013 | HP Designjet Z6100 InkJet Printer
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
My Hp z6100 carriage jamms in the middle along the encoder strip during printing and gives me error 86:01. I have tried cleaning the encoder strip and still having the same problem
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Jul 29, 2011 | HP Designjet Z6100 InkJet Printer
What is the error 42:10? I keep getting this error and sometimes error 86:01, please help. When I start plotting a map or in this case early this morning on my first map I got this error 42:10, so I turned...
42:10 is carriage motor error, 86:01 is carriage jam. Check slider rods (both upper and lower) and carriage oil pads are lubricated, clean encoder strip. Is your printer is shaking too much? Place it firmly.
Feb 08, 2011 | HP Designjet Z6100 InkJet Printer
Hp z6100 turns itself off! no error code just switches off! Makes loads of beeps and sounds like a fax machine! Help
Jul 30, 2010 | HP Designjet Z6100 InkJet Printer
Oct 28, 2009 | HP Hewlett Packard Designjet Z6100 InkJet...
01.2:10
Problem
Description:
ISS PCA problem.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
Hp designjet 1050 problem
Oiled the slider rods and ensure there was no debris or damage in the printhead path.
You may also want to check the quality of the encoder strip *CAREFUL! IT IS VERY SHARP* and the belt that moves the carriage.
Nov 14, 2008 | HP DesignJet 1050c InkJet Printer
HP Designjet Z6100 InkJet Printer Logo
307 people viewed this question
Seeker5211
Seeker5211
