Question about Kenmore Elite Oasis 27052 Top Load Washer
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
Model 110.28062800
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Posted on Nov 09, 2014
  • Greg Ingram
    Greg Ingram Nov 09, 2014
    It's not belt driven,
  • gospelstuff Nov 09, 2014
    Well hate to say it but u may have a bad hub bearing? or tranny going out but like I said u may just have some object stuck inbetween hub and housing?
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
Engine makes whining sound
Take the belt off and spin all of the pulleys. the bad component should be obvious. high pitch whine is usually alternator bearing for the 98 3800 its timkin part# 100ccab or it can be the power steering pump(but the pitch will change as your steering if it is that) water pump, idler and tensioner pulleys(if you have to change either one, replace the tensioner itself). if you have the supercharged model there are a few parts that can whine( or the s/c is low on oil.)
Apr 15, 2012 | 1998 Buick Park Avenue
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
I have a Kenmore washing machine model 23832100. During the spin cycle it has a high pitch whining sound.
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100
You'll see a number of diagrams of the component parts of the washer.
I can think of two possibilities. One is relatively easy to fix and the other may take a bit more work.
1. These washers use a Motor coupler between the motor and transmission. It consists of two plastic pieces with three prongs on each that mount on the motor and transmission. Between them is a rubber piece with six holes. Over time, the rubber piece may wear such that you may hear a whine especially during the spin cycle.
To check the motor coupler, see the following for how to gain access.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
2. These washers use a Clutch to transmit power to the tub for spinning. It's also possible that the bands on the clutch are slipping during the spin cycle.
In order to check the bands, you'll have to pull the transmission. \
It's not as difficult as it sounds.
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE TUB .
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Check the clutch bands and if worn, Sears has a replacement band kit ($27.48). You don't have to pull the clutch off and or replace the entire clutch ($40.49)
Also see the Whirlpool / Kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jan 19, 2010 | Kenmore Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
150 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
