How do I set up a lcf421070snbsmart the operating instructions supplied with it are rubbish
Need to know how to set up the computer side
I got a toshiba portege m200 how can i get it too factory settings
I am no computer expert whiz-kid but I think it is almost impossible to restore the factory settings once a computer has been in service for a time as every time it is used it gathers rubbish - temporary files, cookies, empty folders and things that constantly go on behind the scenes. There are also extra programmes, software and documents that gather in all sorts of places, each slightly affecting how the computer works and responds and virtually impossible to get rid of and if you do get rid of some of them there is often a driver missing from either the operating system or one of the accessories.
The only way to get it back to the way it was when new would be to format the hard drive and reload the operating system.
Mar 26, 2016 | Toshiba Computers & Internet
My web cam is rubbish and it has lines going through it like an old tv set!! any ideas of what i can do?? thanks guys
Having lines on your webcam might be a hardware related issue.
However, before we come to that conclusion; you may also try installing the webcam driver.
If you need any help related to the webcam driver installation, please provide me the below details:
1) Make and model of the Laptop.
2) Operating system installed in the computer.
Thank you..
Feb 19, 2015 | Toshiba Satellite Computers & Internet
What does flashed the computer mean
The correct term is to "flash the BIOS". The BIOS (Basic Input-Output System" is a small, physical chip hardwired onto every computer motherboard. It is key to booting and running your computer; when you press the power button, the power supply starts and the very next thing that activates is the BIOS which sends instructions to the CPU (your processor) to activate your hard drive and other devices (DVD drives, USB ports, etc.) which has your operating system (aka Windows) and boots Windows. Sometimes you have new technology you want to install on an old machine, and in order for your operating system to "see" it the BIOS must be updated with new commands. So "flashing" means that you overwrite the BIOS with a new set of instructions. No BIOS should be flashed unless:
>You absolutely need to
>You know exactly what you are doing and how to do it
>You know exactly what to do if your flash goes bad.
If a flash is done improperly you will ruin your computer and cannot boot. Period. Sometimes it can be fixed with a re-flash, but don't depend on it.
Sep 27, 2013 | 1990 Plymouth Laser
I want to download FileSearchEX on Windows 7 but get lots of rubbish also. Which is the best site to go to, please?
I always use the advanced setting when installing software from these types of website. It should then give you the options of not downloading the toolbars etc. Also create a folder in you computer drive that you can save these software too. In your case name it "SearchEX". This makes it easy to remove should you need to.
May 25, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I need to do a factory reset on my daughters esprimo mobile V5535. Her laptop keeps popping up with vista total security rubbish and says she needs to purchase a key. i just want to get rid of this rubbish...
you need to use the recovery disc that came with laptop back up all important files first to either external hard drive or usb drive then restart computer press F12 on your computer put recovery cd in dvd drive then select boot from cd in the list that comes up when you press F12 when disc loads choose factory restore option.if you haven't got the recovery cd then you need to get your hands on a copy of windows some good deals on ebay at moment
May 20, 2010 | Computers & Internet
Computer running very slow , a notice keeps popping up that the virtual memory is low and it is trying to increase it
You're running too much at the same time. I would not recommend touching the settings unless you are positive that you know what you are doing. However, if you are confident that you know what you are doing, and you want to take matters into your own hands: Start Menu Control Panel System Advanced Tab Under Performance, click settings, go to the Advanced tab, and set more virtual memory
Jun 11, 2009 | Computers & Internet
NO SETUP INSTRUCTIONS SUPPLIED WITH MACHINE. PLEASE SUPPLY
1. well its quite simple. all you to do is to connect the USB cable to the computer from the Printer (the printer also has a port for the USB)
2. then connect the main telephone line into the port labelled "LINE" behind the printer.
3. then you connect one end of the extra telephone cable supplied to the port labelled "EXT" behind the printer and the other end to the regular port on the telephone.
4. plug - in the power cable and put on the printer.
5. then you put the CD into the computer and run the set-up from the CD which is fairly easy.
6. after a few minutes you should have your printer running.
Nov 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Printing rubbish
What computer? What Operating System? What type of connection to the 1018? What driver type?
Mar 24, 2008 | Ricoh Aficio 1018 Printer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
