Question about Kenmore Elite 45986 Front Load Washer
Nothing going on
My washing machine humms, but doesnt water is coming out, there is water sitting in there, but it won't drain, I event put a few pieces of cloths in to see if that would help.... nothing is happening.. I even switched the cycles, & nothing. Please help.... I can't find my manual. I have only owned it for two years..
  • 156 Answers
Re: nothing going on
Need to remove the lower panel below the door and unscrew the big white cap and clean out the pump pluged up this will fix the problem beware all the water in tub will run out on floor if hose coming from pump is not pinched closed
Posted on Feb 28, 2008
0 characters
3 Points
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
Washer washes but won't drain and won't proceed through the rest of the cycles. It just humms.
hi it sounds like your pump is blocked have you tried cleaning your filter these pumps are magnetic and will sit and hum if blocked
Nov 15, 2011 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
My washer will not go into a spin cycle...I have replaced the ccu and mcu boards and I still have the problem....what could it be?
if the water isn't draining the pump is clogged,send the model number so i can look it up,remove the bottom panel,with a shop vac vac out the water in the tub,next if you have the pump with the middle piece that screws out,loosen the middle part of the pump and vac up the water as it comes out,do this until the water is drained out,then take out the middle clean out piece and make sure nothing else is in the pump and in the hose,put it back together add some water and see if it spins and drains.let me know what you find and send the model number,if the pump humms and water doesn't drain the pump could be bad or something is still stuck in the pump
Oct 22, 2010 | Kenmore HE2 Plus Front Load Washer
Won't spin cycle
when sitting for the last spin it may be out of balance,when you have no cloyhes in it,put 1cup of HE clorox bleach and let it sit in tub over nite,then run on heavy duty wash hot water cycle.(no clothes) this should open up drain pump.this may take several trys.
Jul 31, 2010 | Bosch Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin won't agitate
This is a link showing the part I suspect needs replacing in your washer. It's the motor coupler -- when it breaks, nothing turns but the motor itself.
May 06, 2009 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
