Question about Kenmore Washing Machines
4 yr old Kenmore Elite HE when in spin cycle it makes a whining sound like a button is inside the tub.
    Problem Solver:
  • 15 Answers
Could be a bad bearing in the back or lots of lint somewhere causing frictions, Straighten out a metal clothes hanger and stick it around the edge, if lint starts coming out then maybe that's the problem there
Posted on Nov 19, 2014
  • 37 Answers
SOURCE: Whining during spin cycle
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Posted on Jan 17, 2008
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
mikedurland
  • 481 Answers
SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Posted on Aug 04, 2008
jsrock516
  • 5911 Answers
SOURCE: tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Posted on Oct 03, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
Kenmore Elite he5t sounds like a jet engine getting ready for takeoff during the spin cycle. It is extremely loud. Not sure why it all of a sudden started doing this.
Ahh yes, hopefully it's less than a year old. This is likely the main bearing located within the plastic tub. If it has sounded like this for quite some time, you will need a few new parts. The plastic tub (or "tub kit") and the stainless steel drum (which includes the shaft that the bearing rotates on). When did you buy it? If its under a year old, labor will be warrantied with the parts, but the parts themselves should be under warranty as they have a 10 and 25 (or lifetime) year warranty each.
Good luck! We just had this fixed, but now have a new problem. the front button panel will not light up. :(
Feb 19, 2010 | Kenmore Elite HE5t Washer
Wet Clothes and some sandy crud left at spin cycle end
Make sure you plugged the wires back in that you unplugged to take the case off. The plug located under the panel. This is you lid switch and if it's unplugged it will not spin clothes out. If it is plugged in, you might want to go back and take the pump off. Once you have, check inside the drain tube that connects from the pump to the tub. Make sure there is nothing inside it. Sometimes lint will build up inside it, clogging it.
Please rate solution
Oct 02, 2009 | Kenmore 22422 Top Load Washer
Loud noise during spin cycle Kenmore Elite model 110.20952991
check balancing
look in side the lid small clothes some how may fix anywhere inside
Jul 23, 2009 | Washing Machines
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore front loader makes a knocking when it spins.
how old?sounds like the bearing are going bad,on yours the tub and bearing are one unit,so you have to change out the whole thing-mike
Mar 24, 2009 | Kenmore Elite 45986 Front Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
zato2
handiman518
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
