Hello..I have a hisenes TV ...model#.f46k20e ..the menu or setting goes crazy blinking a lot.and valuem goes to100% by its self.and turns on by its self also...what would be wrong..I'm guessindf its maybe a control board but don't know..
  • 3,506 Answers
Go to the mfg website and look for trouble shooting help there.
Posted on Nov 08, 2014
  • irving Nov 08, 2014
    Thanks..I will do so.
SOURCE: VS-50111
no power
Posted on Mar 11, 2008
  • 11 Answers
SOURCE: mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
Posted on Dec 13, 2009
ladywinn
  • 5138 Answers
SOURCE: where do i find the small signal board in rca
Problem is not going to be in your Signal Board SSB,
It is your Front Panel Board/ the board that Has Vol- Vol+ CH- CH+ OFF/ON -POWER/ Either contact switches are Bad OR Very Diry Take Contact Cleaner or you can use rubbing Alcohol to clean contacts.
Posted on Jan 18, 2010
Testimonial: "thank you so much i found the board and clean the the all buttons with the Alcohol and its work ,no more menu screen come again thanks again."
  • 58 Answers
SOURCE: We have a Mitsubishi tv Model WS48311 purchased in
You have bad switches on the front panel. Press them 50+ times to release them. Failing this you will have to replace them. You can disconnect the front panel to confirm this.
Posted on Jul 06, 2010
SOURCE: When I turn the set on ,it stays on for maybe 3
needs a new lamp...just replaced mine with the same symtoms as yours and its like brand new now..good luck!
Posted on Sep 11, 2010
Will not turn on
If the green power light comes on for a few seconds at turn on and goes out do the self check this set has(I will be here on and off for a while):
when light goes out on the front of the set press and hold BOTH the menu and input (input can be labeled source on some models) for at least five seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code if any is found and I will direct you.
Note that if you have removed power from the set that will clear the error code and give you a 1,2 error which of course is no error--you have to plug set up and try again to turn it on and do the self check when it fails.
SD TECH
Dec 10, 2012 | Mitsubishi WS-65819 TV
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishiti model no.vs60705come on go off
Set is in shutdown---it MAY have the self check feature but I think it is too old---when power light goes out on front of set press and hold Menu and Input (device) for 5 seconds or longer--release both and look to see if green power light blinks a sequence---like 2 blinks, 2 blinks, a pause and repeats for a total of 5 times.
If it has the feature let me know what blink code you find.
Apr 27, 2012 | Mitsubishi Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
When you turn it on the tv stays on for 5 or 6 seconds then goes off
When it shuts off and the power light goes out do the self check this model has:
On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both.
Power light should blink a two digit error code at least five times.
Most common are 2 blink, a pause and 2 blinks or 1 blink and then one blink.
Let me know what you find and I will assist you.
SD TECH
May 17, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
Tv turns on for 5 seconds no picture and shuts off.. red light blinks 8 times
hello. problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
When I turn the TV on it shuts itself off in two seconds. It's model WS65909 Diamond Series
This model should have a self diagnostic feature:
Turn set on and when power light goes out----Press and hold on the front of the set both the MENU and INPUT buttons for 5 seconds and release both.
Power light should blink a two digit error code---most common is 2 blinks, a pause and 2 blinks--set will repeat the code about 10 times.
Let me know what the error code is and I will tell you what it means and what may be needed to fix it.
I am here to help people--If you have any questions or need help let me know.
Regards, SD TECH
Oct 06, 2009 | Televison & Video
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
My model is a WS-55511. I turn on the TV, the
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
