Question about Car Audio & Video
Iturn stereo on but does not light up in display and its like its freezed
  • 3,506 Answers
What make, model etc??
Posted on Nov 08, 2014
How do iturn the service light of on a sabb 93 2006
on the SID press customise then select system settings then service info and select reset service info. If the option to reset is not there you will need to change the date to a date beyond the 'Days to service', reset option will then appear. when reset, return date to correct setting. (to change date press and hold the info select button when the date is displayed.
Oct 14, 2009 | 2003 Saab 9-3
Beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
Jul 21, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
AC display won't dim after stereo installation
If you disconnect the stereo, does the temp. display go back to working properly? Did you connect the stereo Illumination wire correctly? Are all the other stereo wires connected correctly? Double check what the wires in the aftermarket harness are supposed to be and don't just go by color.
Jun 17, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
When iturn on the comouter the screen is blank
try connecting an external display and switching the image to that one. if that works, you know it's your internal display. if it gives the same blank screen, it most probably is the graphics adapter on the mainboard.
May 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Every time iturn on my stero it says protect what is the problem and what can i do to fix it
u have a short... find a short u left by... it says protect because the stereo protects itself from shorting out.
Apr 10, 2009 | JVC Silver/brown Compact Component System...
My 24 inch monitor will notwork iturn it on and it flashes analog digital like always but then it goes blank
be sure that the frequency of that monitor can supports with your AVG ( Display Adapter).
Jul 12, 2008 | Computers & Internet
My mp3 player
ok here is the thing mp3 players work on bit rates ,
meaning if your bit rate is over 128 bits
unit will act weird
so what i suggest is you erase and reformat and only install songswith bitrate of 128
here is a link for ree songs dont sign up to b a member just use tral version and you can also get videos
www.limewire.com
rembe only 128 bits and you wll be able to get more on your unit
hope this help
richard from chicago
Feb 22, 2008 | SanDisk Sansa e200 MP3 Player
My mp3 player
I would recommend you to get the firmare upgrade for your device i you have not done so..that usually solve the problem you are having ...
Jan 26, 2008 | SanDisk Sansa e250 MP3 Player
Dim Display
On newer stereos, you might have to experiment with the "panel" wire.
I just installed a VR3, and discovered that the more voltage on the "panel" wire, the dimmer the display.
With no connection, you get full (daytime) brightness. With full voltage, you blank the display.
I wired mine up to the car's instrument lights through a 10Kohm trim resistor so I could adjust the "night" intensity. But if I dim the car's instrument lights, the stereo gets brighter. Oops.
Older car -- I can't just flip a software bit. ;)
But I gather a lot of new stereos are like this. The display on my (factory) stereo in the Mitsu dims a fixed amount when the lights come on, but doesn't adjust with the car's instrument dimmer.
Sep 23, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
