Question about Gateway Computers & Internet
How to reboot GT5662 without disk? Will only show to reboot with disk. Can't get to start menu
  • 3,506 Answers
Check mfg website
Posted on Nov 08, 2014
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
V3-531 reboot without disk
You don't need disks to reboot. Just click "Turn off computer" under the start menu, and then click "Reboot". If that doesn't work, hold down the power button. After ten seconds or so, your computer will shut off, and you can restart it again simply by pressing the power button again.
Jan 31, 2013 | Computers & Internet
I need what positions to plug in the PWR & PWR Led on my gateway mother board. It's a GT5662
Hello download the user guide here:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=4006254R
Or here:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2969
The files from these sites needs to be unziped and you need adobe reader to read the content.
The front panel connector look like this:
Hope this will help you
Dec 12, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
I don't have my password & need to change it
Do you want to change laptop password? If so, you can use Smartkey Windows Password Recovery to help you,
Step1: Download Windows Password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Jul 10, 2012 | Computers & Internet
My desktop sceen shows Blue screen with error memory dump contect ur hardware vender
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 14, 2012 | Computers & Internet
I would like to reboot my computer to factory settings (like when I first bought it). I've tried f10 on my keyboard at startup and it doesn't work, it continues with the startup process. I've...
You forgot to tell us the Motherboard type.
Click either F2 or Delete( depends on the type of board ), after you started the comp and shows the memory and HD capacity on the monitor.
Bios setting will then pop up, then go to maximum default settings....save and exit.... it will restart by itself.
Hope that helps!
Sep 15, 2011 | Computers & Internet
I have an old packard bell pc and it needs to be rebooted but i haven't got the original floppy reboot disc how can i do it without the disc ?
By rebooted, I assume you mean reinstalled? You cannot reinstall a PC this old without the operating system disk. New PC's have a utility partition that contains the reinstall package. You will have to purchase that OS from ebay or some other site.
Jun 02, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
When turned on screen lights up with apple logo but nothing else happens
reboot while holding the option key down. It should show you available hard drives from which you can startup.
Choose the drive and then press return or enter.
Then restart.
If nothing happens, turn off the laptop and insert your Mac OS disk and then reboot while holding down the C key.
The computer will load the system on the disc instead of your hard drive. Then instead of reinstalling the system software, look at the top menu and find the Disk Utilities program and run a repair on your hard drive.
Then reboot without the disk in the drive.
May 10, 2010 | Computers & Internet
I cannot get my gateway gt5028 to reboot,, i have no disc,, people tell me yiu can reboot and get computer back to normal without one,, help!!
there are 2 things about reboot that is the reboot from the bios or reboot from the windows... if you mean you can't reboot and there are no hard disk as your primary hard disk try to check if the bios detected the hard disk. by pressing Delete key when you start to reboot the computer... make sure there are someone with you who knows something about the computer BIOS. if not keep in touch.. in Main menu in BIOS you will find If the computer detected the hard disk, if not detected try to check the IDE/SATA cable or Power Cable of your hard disk. Check if that hard disk is the first boot in the Boot section of the BIOS, if not then change the Hard Disk as your first boot.. That will help you boot your computer properly in windows..
Dec 05, 2008 | Gateway GT5028 PC Desktop
Computers & Internet Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
