I have a Sanyo AWD-L703HCTP dual wash and dry. I switch on then before I can do anything E C6 comes up on the display and says its locked and switches off automatically. Daniel Scott answered, saying
I have a Sanyo AWD-L703HCTP dual wash and dry. I switch on then before I can do anything E C6 comes up on the display and says its locked and switches off automatically. Daniel Scott answered, saying he hoped the error code was E06, and then gave an explanation. The error code on my machine is EC6. What does this mean? How can I fix it?
  • Anonymous Mar 12, 2017
    I received the EC6 error when I tried to use the dryer function (I think it's some sort of thermostat safety control). The problem can be solved by pushing the red re-set button at the top of the machine. Disconnect your machine from the mains power. Then open the top cover by undoing two screws at the back, and two screws at top left and right. To access the top left and right screws, you'll need to remove the 1-cm square plastic cosmetic patches. On the top of the machine there's a metal bar running from left to right (it's part of the frame). Just underneath the metal bar, towards the front-right of the machine, there's a small red button connected to two wires. Push this button down gently until it clicks. Close the top cover and reconnect the mains power. The machine should now work.
  • 3,506 Answers
Check the Sanyo website
Posted on Nov 08, 2014
2 Suggested Answers
SOURCE: I have a Sanyo AWD-L703HCTP
U4 Error
Posted on Oct 12, 2013
Aeg lavamat error code c6
Found this on the following forum
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
Sanyo washing machine AWD-703HCTP DISPLAYED EH1 ERROR CODE what is the problem
Maybe you have solved your problem, but if not, I haven't much good news, just a website with more info about Sanyo washing machines. That division of the giant Sanyo was sold to Panasonic.
The link for more about the washers is...
Good luck.
Nov 25, 2014 | Washing Machines
2wd vs AWD
Page 13 of owner's manual says:
(if equipped):
Illuminates when the AdvanceTrac
system is active. If the light remains
on, have the system serviced
AWD locked (if equipped):
Illuminates when all wheel drive
(AWD) is engaged/activated. If the
light continues to flash, have the
system serviced.
Page 224:
Your vehicle may be equipped with an All Wheel Drive (AWD) transfer
case. With the AWD option, power is supplied to all four wheels
automatically with no need to shift between two-wheel drive and
four-wheel drive. If your vehicle is equipped with the AdvanceTrac
stability enhancement feature, you can change AWD modes, if desired,
by selecting AWD options through the message center.
For the lubricant specification and refill capacity of the AWD transfer
case refer to Maintenance and specifications chapter.
If your vehicle is equipped with AWD, a spare tire of a different
diameter than the road tires should never be used. Such a tire
could make the vehicle difficult to control as well as result in damage
to driveline components.
Utility and four-wheel drive vehicles are not designed for
cornering at speeds as high as passenger cars any more than
low-slung sports cars are designed to perform satisfactorily under
off-road conditions. Avoid sharp turns or abrupt maneuvers in these
The following sections, Normal operation, Autolock operation and
Disabling AWD, apply only to vehicles which allow the driver to change
AWD modes through the message center.
Normal operation (vehicles equipped with AdvanceTrac
During normal operation:
• the AWD system is in AWD AUTO mode (AWD LOCKED will
illuminate in the message center for four seconds when you first start
your vehicle). The AWD LOCKED indicator in the instrument cluster
will also come on.
• AWD AUTO mode can be overridden by pressing SETUP in the
message center. When you first press SETUP, AWD <AUTO> will be
displayed, then if you press RESET within four seconds of pressing
SETUP, AWD <LOCKED> will be displayed. AWD <LOCKED> provides
power to all four wheels constantly which allows you to operate your
vehicle in severe winter or off-road conditions such as deep snow, ice
or shallow sand. It is not recommended that you use AWD <LOCKED>
on dry pavement.
Page 225:
• AWD <LOCKED> can be cancelled by pressing RESET in the message
center. (The AWD LOCKED display in the message center will then
turn off and the display will return to AWD <AUTO> for four seconds
when the shift is complete.)
Autolock operation (vehicles equipped with AdvanceTrac
If the AWD system begins to overheat, the system will place itself in the
Autolock mode:
• the AWD LOCKED indicator light will illuminate in the instrument
cluster and AWD DISABLED <LOCKED> will be displayed in the
message center.
• AWD LOCKED will be displayed in the message center for four
seconds and a warning chime will sound. This condition may clear
without any action being taken by the driver.
• the AWD LOCKED indicator light in the instrument cluster will turn
off when the AWD system cools down.
• When the system is sufficiently cooled down, AWD AUTO RESTORED
will appear in the message center for four seconds and a warning
chime will sound.
Disabling AWD (vehicles equipped with AdvanceTrac
When a problem is detected in the AWD system:
• the AWD LOCKED indicator light in the instrument cluster will flash
eight times every two minutes in the message center.
• The message center will then display AWD DISABLED for four
seconds, then SEE OWNER'S MANUAL. A warning chime will also
sound. The warning displays and chime will continue until RESET is
pressed (which will clear the message from the display).
• AWD LOCKED can still be engaged by pressing SETUP (the message
center will display AWD <DISABLED> LOCKED), then pressing
RESET. The AWD LOCKED indicator light will illuminate in the
instrument cluster and the message center will display AWD
• To disable AWD, press RESET. The system will go back to AWD AUTO
mode momentarily, then the AWD LOCKED indicator light will flash in
the instrument cluster eight times every two minutes. The display will
then show AWD <DISABLED> LOCKED for four seconds and then
turn off.
Page 226:
• If a serious problem occurs with the AWD system, the AWD LOCKED
indicator light in the instrument cluster will flash 10 times every two
minutes. The message center will also display CHECK AWD and a
warning chime will sound. You can press SETUP to check the status of
the AWD system (which will display AWD <DISABLED> LOCKED),
but the AWD system will be disabled until the system is serviced.
Driving off-road with truck and utility vehicles
AWD vehicles are specially equipped for driving on sand, snow, mud and
rough terrain and have operating characteristics that are somewhat
different from conventional vehicles, both on and off the road.
When driving at slow speeds off-road under high outside temperatures,
use 1 (First) gear when possible. 1 (First) gear operation will maximize
the engine and transmission cooling capability.
Under severe operating conditions, the A/C may cycle on and off to
protect overheating of the engine.
Nov 30, 2013 | Lincoln Navigator Cars & Trucks
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
Mar 27, 2013 | Bosch Classixx WVF 2402 Front Load...
Unlock nokia C6 Australia
You can get the unlock code from any reliable online site. For example you can choose You can get the restriction code for NOKIA C6 from here. This is one of the most trustworthy sites to rely on unlocking. The unlock codes provided here are very accurate and affordable. The unlocking process here is very simple. You will get total guidance on unlocking process. Here are the steps for unlocking a NOKIA C6,1 - Switch on your Nokia C6 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C6.
3 - Compose #pw+CODE+1#.
4 - The Nokia C6 would then display the message "SIM Restriction Off" and will be unlocked!
Apr 02, 2012 | Nokia Cell Phones
Whenevr i switch on my nokia c6 music player it displays 'searching for music n podcasts' n it jst goes on. i hv to switch on again my phn to work properly.. gv me asolution fast plzzz
The most common reasons it is happening is due to a corrupted memory or most probably corrupted firmware. I would suggest try removing the memory card and if that doesn't work, you will need to update your firmware. You can either bring your phone to the nearest Nokia service center or you can do it using the included CD and cable for your phone.
Try visiting Nokia support for further assistance.
Thank you!
Nov 03, 2011 | Nokia C6 Smartphone
How do I put my 09 Suzuki SX4 AWD in lock position ?
You have a switch down by the shifter, on the side. You simply toggle the switch to lock position. You don't what to do that on dry pavement. Just put the switch in auto. The computer will engage and disenage when needed. Don Suzuki guy
Oct 04, 2009 | 2008 Suzuki SX4
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
