Question about Brother MFC-8460N All-In-One Printer
Driver Need the driver update for Window Vista for Brothers MFG-8460N -Printer All in One loaded under XP all it will do is print and when I try to install some other down loads it brings up Paper Port insert CD to continue.I think if i had the update it will load completely.
  • 832 Answers
Plz choose your country and go to support/download for your mfc:
You will find the vista drivers and some more hints (faq) there.
Posted on Nov 12, 2007
My printer will not print anything. It doesn't say any errors. I use windows vista.
You likely need to download an updated driver for Vista from the printer mfg internet connection. Delete and reinstall the printer in the computer as if the printer was new. When it looks for the driver, point to where you have the new driver stored. Hope this helps.
Dec 03, 2009 | Cars & Trucks
Pixma MP500 will not print in black
Presumably you have just upgraded from XP to Vista. I think the old XP printer driver may still be in effect or Vista has given the printer a generic driver with no advanced properties. Have you tried completely removing the old driver, deleting the printer then installing the printer and new driver from scratch? Else try going to the printer device properties and update driver then direct the updater to the downloaded files.
Oct 08, 2007 | Canon Pixma MP500 All-In-One InkJet...
Network printing in vista is offline
Is it shared over a network, or is the driver installed on each PC independently? Have you installed the proper Vista drivers on the Vista PC's? The Xp driver is likely not compatible with Vista. It may be (if you used a disc) that it doesn't contain the proper Vista drivers. I would try downloading the proper driver and re-installing on the Vista PC's.
get it here:
Jul 14, 2009 | Brother MFC-8460N Bundle All-In-One...
I can not get my Samsung printer drivers loaded for VISTA sp2
this time you are going to find MANUALLY your vista driver of your printer, go to device manager and update driver using an inserted CD of your printer... and even your going to update your VISTA its not reason...
Jun 19, 2009 | Samsung CLP-315W Laser Color Printer
WIndow vista have driver?
I have had the same issue, Try this on an xp machine with driver loaded for dc1250 share this printer and then on the vista machine brouse the network and double click the shared printer on the xp machine and the driver should load and vista will print using the xp machine as a print server.
Jul 23, 2008 | Xerox DocuColor 12 Printer
Printing problem
Hi JuanU,
Which version of Windows are you running now? Vista?
If it is Vista, you will need to use the newer 'UltraDriver' for the Opera printer (V1.3.0.0 Issue 1).
This can be downloaded from Magicard's web site here;
NOTE!!! This driver will ONLY work with the following operating systems: Windows 2000, XP, Server 2003 and VISTA. If your PC has a different OS from those above DO NOT install this driver!
If you have an 'older' Opera printer which does not have an 'E' in the serial number, you will need to change the 'PRODUCT ID' from 2000 to 2800 before this driver will recognise the printer.
This is quite simple to do. Download and install the Magicard Support Utility Version 3.13 by clicking on this link;
Run the Utility, select 'USB' for the comms port.
When the other tabs open up, select 'Statistics / Commands'.
In the 'Quick Command' box type;
Then click 'Send'.
Exit the Magicard Support Utility, and unplug the printer's power cable.
Now, install the UltraDriver version Issue 1.
When the driver install has finished, plug the power cable into the printer. The hardware wizard will finish the installation and you will then see the 'Magicard Opera' printer icon in your printers folder.
It should then work fine.
Let me know if you have any problems.
Jul 22, 2008 | Magicard Opera 100 Card Printer
Couldn't install lexmark 8300 printer software on my window vista driver computer
Follow this link to the official Lexmark website and download the driver.
If you can't follow that link, go to On the top menu, there is a link called "Drivers and Downloads". Click it and select your series, then your OS system, and there you go.
The drivers for Vista are finally updated.
I had the same problem for about a year... now it works fine.
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
Hp 1220c window xp driver
i updated my driver for my hp1220C on XP after a crash that stopped the valuable print preview function working ...(printer worked but was print immediate - -and no tool box options etc) . i can't believe i found how to fix the driver ... you need to right click the exe file [before running it] dj1074en.exe or whatever ... and 'properties' - 'compatibility' click near 'compatibility mode' 'windows 2000' - then run it ... and voila -- i now have the print preview and all the lovely functions back again!!!! crazy!! took me 3 hours to find this ... it may well work with vista -- to select the windows 2000 option .. don't know that one ... at least until HP update all corectly and clearly
Dec 28, 2007 | HP DeskJet 1220c InkJet Printer
Can't install to Vista HP PSC 1210
Use Paint.
It's not ideal, but I can scan with my HP PSC 1205 running Vista when I use Paint. Just click 'file' then 'from Scanner or Camera'.
Works a treat.
Sep 23, 2007 | HP PSC 1210 All-In-One InkJet Printer
Brother MFC-8460N All-In-One Printer Logo
115 people viewed this question
James Cagle
James Cagle
Jim Keysor
