Question about Amana Dryers
Why does my Amana dryer product so much lint? I've never had this problem before.
We always clean the inside vent before every load but the amount of lint which piles up under the outside vent is excessive.
  • Amana Master
  • 8,220 Answers
Is your filter ok? small hole in it will do it. I did a video recently on repairing these:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 08, 2014
  • 88 Answers
SOURCE: how to clean internal lint buildup
Buy a lint brush at Walmart or other retail store. It's a long plastic bristle brush that will allow you to reach down in to the cavity of the blower intake. I always use a vacuum hose to **** up what it pulls up so it won't fall back down in.
Posted on Nov 18, 2009
Testimonial: "Thanks much. will give it a go. "
farfield
  • 462 Answers
SOURCE: Amana electric dryer will not heat/ LEA60AW
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
  • 6 Answers
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Posted on Apr 25, 2009
burdfrenzy
  • 348 Answers
SOURCE: My Amana Heavy Duty Dryer will not heat up. It
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Posted on Nov 26, 2010
richroth
  • 9472 Answers
SOURCE: my amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
Posted on May 23, 2012
I have an Amana Dryer, ned7200tw. It was taking forever to dry clothes, took twice through per load. We replaced the heating element 2 days ago, cleaned all the lint while it was apart, and it is still...
Did you check the trap door on the outside of the house where the vent goes outside. If the door is stuck or the end of the vent is blocked you will get excessive dry time like you are having. Also possibly a thermostat inside starting to go bad and sticking.
Mar 01, 2015 | Amana Dryers
Tip
Clean Your Dryer Vent to Prevent Fires
Most people have no idea how much lint gets past your dryer's lint trap. The amount is substantial. Over Time your dryer vent pipe becomes coated with dryer lint. If your dryer vent hasn't been cleaned in over a year, you may have a potential fire hazard on your hands. Once the vent becomes restricted your dryer will take longer to dry a load. Lack of airflow will cause your dryer to over heat. If your dryer vent is over eight feet long, your dryer vent should be cleaned annually. Some of the early warning signs of lint blockage include:
  • Is the top of your dryer hot to the touch?
  • Does your dryer take over 50 minutes to dry a load?
  • Do you ever experience a moldy smell on your clothing?
  • Is dryer lint gathering on the inside of the dryer door?
  • Does it seem like your clothes have extra lint on them?
  • Is your house dusty? Dryer lint is almost microscopic and goes everywhere.
Most dryer vents have a flap or a screen located at the exit. This must be cleaned on aregular basis. Where your dryer vent exit's the building is usually the first place dryer lint will gather. It is very important when you have your vent cleaned they address the exit.
Dryer vents come in all different shapes and sizes. The dryer vent itself refers to the exhaust pipe inside the wall. This pipe should be a 4" steel pipe that exits right outside or some times up through the rooftop. Some builder's occasionally use the more rectangular gutter piping, or the flexible metal piping. Both of these can be inefficient. If your home has a foil accordion type material inside your wall, this needs to be replaced immediately. This material is actually flammable, if you ever had a dryer fire it would have no chance of staying contained.
A dryer vent that exits on to a tile roof can pose another potential airflow restriction. Much of the time builders use the same gooseneck type exit as on a standard shingle roof. Unfortunately these vents aren't long enough, and tend to vent right on the tile with very little space. The fix for this problem is to fabricate an extension that raises the vent at least four inches above the tile.
Another common problem is a crushed transition tube. The transition tube is the pipe that connects the dryer to the wall vent. Most of the time delivery people use the foil type transitions because of ease of installation. Unfortunately this material can easily become crushed or restricted. This type of material is actually paper and can ignite. Unlike the all metal venting material that the dryer manufacturers recommend this material is a real fire hazard. (see your owner's manual or the labels on back of the dryer.)
Unfortunately a blocked dryer vent can break your dryer. The two main parts that break, are the element and the thermostat. The excessive heat produced by a blocked vent is a repair waiting to happen. Many of the new high efficiency dryers have warning lights that tell you when your vent needs cleaning. Some of these dryers even lower the temp on their own to keep from overheating.
The best way to test your dryer vent's efficiency is to disconnect the tube from the wall and dry a load of clothes. If your clothes get dry in a reasonable time it's your dryer vent. Over 15,000 dryer related fires occur every year. Most of these fires could have been prevented, with an annual vent cleaning. Don't become a statistic get your dryer vent professionally cleaned today.
on Jun 07, 2011 | Dryers
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Sep 09, 2009 | Maytag Dryers
My amana gas dryer is not heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 04, 2009 | Amana NDG5800 Gas Dryer
I think The dryer takes very long time to dry clothes
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Feb 24, 2009 | Amana NED7200TW Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryer screen
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
Apr 06, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
94 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
