Question about Electrical Supplies
I have Duromax XP100000E generator. Starts fine with choke but shuts down after about a minute or two. If I take it off choke it shuts Dow immediately . I checked the spark plug and oil level and both
I have Duromax XP100000E generator. Starts fine with choke but shuts down after about a minute or two. If I take it off choke it shuts Dow immediately . I checked the spark plug and oil level and both are within spec. I cleaned the sediment cup and filter. Any ideas?
    Sergeant:
  • 149 Answers
Look for a vacuum leak, carb gasket, manifold gasket, vacuum hose broken or cracked etc.
Posted on Dec 05, 2014
  • 67 Answers
SOURCE: It starts fine and runs on choke but not off choke
It sounds like you are not getting enough gas. I think it's the diaphragm, When you take it off of the choke diaphragm controls the gas flow, apparently yours is just shutting down. It's very inexpensive, and very easy to replace. Good Luck :)
Posted on Feb 23, 2009
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
SOURCE: Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Posted on Aug 29, 2009
  • 7 Answers
SOURCE: 2 year old honda eu1000i generator with new spark
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Posted on Sep 10, 2009
THENTHEREWER
  • 131 Answers
SOURCE: I bought a used coleman powermate 5000 generator,
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Posted on Jan 07, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
I have a 4500e duromax starts up and runs then shuts off clean carberator same problem looking for suggestions
On the WEB
manual-duromax-elite-mx4500e-manual ' Generator Nation
www.generatornation.com/tag/manual-duromax-elite-mx4500e-manual/
DuroMax Elite MX4500E 4,500 Watt 7 HP OHV 4-Cycle Gas Powered Portable Generator With Wheel Kit & Electric Start Reviews. By Generator Man Posted in ..
Jul 31, 2015 | Cars & Trucks
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
BRAND NEW ENGINE. USED THE FIRST TIME DURING HURICANE IRENE. OIL LEVEL IS FULL, USED REGULAR GAS AND HAS BEEN CHECKED FOR IMPURITIES. PROBLEM IS THAT AFTER 32 HOURS, THE ENGINE WILL ONLY RUN FOR 15...
Hi, if it re starts immediately and requires choking it is a fuel related problem. If it has to sit for a while before restarting, check for lost spark as soon as it stops. If no spark make sure the unit is level and oil is full when sitting level otherwise the oil cutoff switch will shut it down. If oil and unit levelling are ok and there is no spark the cdi unit is most likely faulty. Hope this helps, regards Phil.
Sep 06, 2011 | Gentron Electrical Supplies
I have no manual for my Powermate Generator and it has never been started. Any advice on type of oil, start up procedure, and maybe more important shutting it down?
1- oil type: when you buy it...tell them u want small generator oil...its all the same.
2- start up:turn the red button (on and off button) on(usually UP).
then i prefer choking the engine.
(make sure the feul knob is open)
then pull the string ...and when it starts runnin undo the choking immediaetly.
3- shut down:simply turn the red button off (usually DOWN)..it might keeps shaking...if so...then choke it again.
i hope i helped...send me an email for more details
Oct 10, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
116 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
