Haier 26" LCD TV--loose headphone jack.
I know it's the jack--only one channel plays: Moving the tip around--the alternate channel plays. Maybe I'll attempt crude-tool "gumby-pokey, bendy," first! Foiled again by a cheap PRC part--the weakest link in what's proven an otherwise pretty satisfying, old LCD TV. I suppose that I must unscrew, enter--solder out, toss, solder in the replacement, and test out: There isn't an easier way? What I think I'll do is to obtain an external, wired (shielded) jack which will dangle out from the side--this then would prove far easier to manage in the future. (How efficient!: I answer my own question!) Does anybody offer any tips to simplify?: Any tips to avoid replace or mod? (The RCA jacks on the back don't allow HDMI use, of course. Yeah, I might instead convert the coaxial output (or optical-I can't remember--maybe both are available I don't care)--more wires, another used, covered outlet, vampire current, more complexity. The jack ideally should actually function nominally, nonetheless.) I'll visit RS in a few, first--I suppose. (Yeah, the co. survived--restructuring instead of liquidating. Arduino is saving the co.) Thanks! I like the idea of dongle--maybe with extended wires--hummm--perhaps that isn't necessary--just replace innnards in the removable, unscrewed shielding and solder there--that depends....) Thanks!: Too often these days many of us rely upon this cheapo, PRC part--a part proving hardly an afterthought--a part generally never invoked at all!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Sounds like you've got it figured out
Posted on Nov 09, 2014
Testimonial: "Thanks!: I was afraid of that!"
  • 6 Answers
SOURCE: Looking for a schematic diagram
It would be less trouble to disable the internal speakers from the television's setup menu and connect to a set of powered speakers or a receiver using the built-in audio outputs. It will be a challenge to get good sound quality and levels from the headphone jack.
Posted on Apr 26, 2008
SOURCE: Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Posted on Dec 26, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Which external speakers work with an Emerson 19" LCD digital TV?
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
Posted on Feb 13, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
welcomejee
  • 10594 Answers
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Posted on Sep 26, 2009
Testimonial: "Good advice, but didn't work. :("
Need help to hook older recorder dvd unit
I am assuming you are looking for a way to get a video signal from the TV to the recorder. Most TVs already have a composite video input. If you want to get a signal to your recorder, there are HDMI to composite video converters available for around $30 US. There are also composite video to HDMI converters. You can then get the audio from the audio out (headphone) jack.
Sep 21, 2013 | Toshiba 26 26AV502R 26 in. LCD HDTV
I have a Static noise coming from the right channel of my mixer. I hear it coming out the right speaker as well as the right ear of my headphones (jack). How can I fix this?
That sounds like a bad connection but it can also indicate your mixer has a problem. If it occurs on all channels it is the mixer, if only one then the problem is in the input. Check your cables, they are a big culprut in problems like this.
Jan 08, 2013 | Stanton SA-5 DJ Mixer
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
May 01, 2012 | LG 26LG30 26 in. LCD TV
How do I remove the base of a Haier TV -- model number HLH26ATBB?
THERE IS 4 BIGGER SCREWS ON THE BACK OF THE TV TAKE THEM OUT AND SLIDE THE STAND OUT ....SCREWS ARE RIGHT BY AMP JACK HOOK UPS....
I HOPE THIS HELPS.. GOD BLESS..
Mar 19, 2011 | Haier HLH26ATBB 26 in. LCD Television
Headphone jack does not cut out speakers when in use
This happens when you didnt insert the jack properly in the socket. Please insert th jack properly,it sholud be fully in.
thanx
Jul 20, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
The tip of the headphone jack broke and got stuck inside our lcd tv's headphone port. Now the tv has no sound unless you put the head phone
You need to lay the TV down on a carpet or bed, take the back off and possibly the board that has the jack to poke the tip out from the other side.
May 25, 2010 | Samsung LN-S4051D 40 in. LCD Television
Sansa
do you mean out of the headphones. if so just try moving the headphone plug around in the audio jack but also keep the music plying to tell if you have figured the problem out or maybe just try a new or different pair of headphones
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
JVC LCD Lost Sound
Yes it is repairable
Do you get good audio from the headphone jack?
If yes, then it is the Audio Amp or some component in the Audio Circuit
If NO, then then Audio Switching IC is defective.
Expeens will depend on the person fixing it. expect $70-100 parts. I think labor is normally $80-120. so $150-220 total.
You can get a new 26" for that though. If the headphone works then the Audio Out of the TV will work. I suggest a miini system for audio out.
Mar 10, 2008 | JVC LT-26X506 26 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
