Question about Dehumidifiers
Unit stays on for approx 13 min then pwrs off and i cannot pwr back on for awhile. please advise corrective action.
Unit has been cleaned,placed unit on 35% humidity, timer was not activated nor showed it was on, unit ran for about 13 min, of that 13 min the compressor ran for about 7 min until unit pwrd off. I can not pwr unit back on. No water collection took place during run time. After awhile I can pwr unit back on with the same results.
  • 3,506 Answers
Either the humidity sensor is defective or there is possibly a thermal etc protection device that is malfunctioning.
Posted on Nov 08, 2014
  • THOMAS BIRDSALL
    THOMAS BIRDSALL Nov 19, 2014
    Sorry so long to reply. You led me right to the problem. The compressor switch was bad on the control board. Did a r & r of part and now works like a champ. Thank you...$36 part vs a new unit...thanks again.
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
KOakaKO
  • 135 Answers
SOURCE: dehumidifier does not collect water
The only thing you really need to check is that collector coil that the the water is supposed to condense upon, much like the "sweat" on a glass of ice water. If that collector coil is not nice and cold, then your machine needs freon or has some other serious problem.
Posted on Aug 04, 2007
  • 121 Answers
SOURCE: Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: customerservice@lge.com
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
SOURCE: unit runs but no water collect
I unscrew the cover were's the air is ****'s inside and I just clean with water pressure.I beleive I have to do this every six month.The problem was;no more water collect,less air came out and the unit was very hot.Only clean the filter is not enough!!
Posted on Aug 25, 2009
  • 117 Answers
SOURCE: My dehumidifier runs, but no water is collecting.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Posted on Jan 05, 2010
Flooded floor
yes I agree that you should not have layed it down , please wait for 48 hrs now to run it again with unit in upright position
next id go over unit and look all all hose's seems a bit of mold builds up inside of these very often , Wight id always say to give it a little spritz of bleach water every 30-60 days or so to clean it out and keep your pipes flowing freely
one of those little bottles of compressed air for computer cleaning goes 4 miles to cleaning out little holes and such on these things
Jul 26, 2015 | Danby Dehumidifiers
I have a Frigidaire Dehumidifier, Model FAD704. the Clean Filter lights keeps coming on and the unit stops running. The filter is not dirty. I take it out and put it back in and unit runs for awhile and...
Hello Winl, thank you for your inquiry!
I see that you are having issues with your clean filter light coming on in your Frigidaire dehumidifier. From what you are describing it sounds like a possible issue with a sensor within your dehumidifier. I would recommend consulting with your manufacturer to see if they can provide any additional assistance towards a resolution. Best of luck! -OOS
Dec 12, 2014 | Frigidaire Dehumidifiers
Kenmore dehumidifier shuts off after approx 5
this could be a missadjustment of the humidistat on unit , i suggest to reconfirm your %rh settting on faceplate
70% rh is considered normal
Oct 16, 2014 | Dehumidifiers
Frigidare fad704tdp evaporator not working, unit does run
Good Morning Friend,
I understand that the evaporator is not working on your Frigidaire dehumidifier, model# FAD704TDP, even though the rest of your appliance is still running. Please check the following:
    1)Please make sure there is enough clearance around your dehumidifier. There needs to be a minimum of 12 inches all around your appliance for it to operate correctly.
    2)Make sure that the air movement through your dehumidifier is not blocked. Clean the grill with the brush attachment of your vacuum. Also, clean the filter. You will do this by removing the bucket, then pulling the filter downwards. Wash the filter with clean water, and then dry. Re-install the filter, and replace the bucket.
    3)Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). Your dehumidifier will not work properly if the temperature is out of this temperature range, or the performance of your appliance will fall greatly.
    4)The "Compressor" circuit has an automatic 3 minute time
    delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FAD704TDP Dehumidifier
Model BHD-301-D Will run from 1 min to 4min then shut off. I've tried all setting from 3 to top does same thing. I have a wet basement so it should stay on all the time. If I unplug it and then plug it...
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1, 2. & 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to trouble shoot and solve the problem. Thanks for choosing FixYa.
Aug 06, 2011 | Comfort-Aire BHD-301 Dehumidifier
I bought this unit on 13 August 2009. The unit runs, the bucket is in place, the filter is clean, but it doesn't remove any moisture from the air. The unit is in the basement in the exact same place it...
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
5. Ambient air temperature at floor level is between 40 - 60 degrees.
level
problem.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 29, 2011 | LG Dehumidifiers
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Jun 02, 2011 | Dehumidifiers
My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 29, 2011 | Haier 45-Pint Dehumidifier
Water not going into hose or bucket
where are u located and where aqre u using the unit
a dehumid wont work properly below 60 degrees
or 40 percent humidity
Oct 17, 2009 | Goldstar DH304 Dehumidifier
Delonghi de400p
same thing happend to me. I wasnt sure if it was the settings or me. I unplugged it for awhile, read thru the instructions turned it back on setting it according to the instructions and it began to work again. Not sure if it had to do with the unit being off for awhile or I entered the correct settings. Im just happy it began to run again
Jul 19, 2008 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
74 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
