Question about Kitchen Ranges
What steps do I take to repair a Magic Chef Oven that shorts when you plug it in?
When I plug it in it blows a fuse
  • 3,506 Answers
You must finf the cause of a short circuit in the system.
Posted on Nov 08, 2014
My Magic Chef microwave oven blows fuse when i open door
If you're blowing fuses from opening the door that is the sign of a electrical short . You'll need to call a electrician to check it out. Changing the fuse in this unit can kill you. There's a capacitor that holds stored electrical energy that is dangerous. My good friend died from trying to change the fuse in his. Get a professional to check it.
Feb 05, 2015 | Magic Chef MCO160UW White Over-the-Range...
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
SOCKET GOT POWER BUT NO DISPLAY
There is a fuse inside that is probably blown. If you replace it and it keeps blowing the fuse when you open and close the door, that means a problem with the door switches sequence. I could run you through that step by step.......
May 20, 2011 | Magic Chef MCD1611ST Microwave Oven
The microwave fuse keeps blowing up. Any idea why?
My Magic Chef microwave keeps blowing fuses (5 fuses) when close the door. Anybody has any idea? It is the first and last time time that I buy Magic Chef's products if their enginers don't come out with a solution because I just got it just over a year.
Thanks for your time and your expertise.
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
When started to heat,blow fuse.
What fuse??? the power outlet fuse of the electric circuit?? the microwave fuse inside??? remember microwave oven need a lot of power you should not plug anything els on the same circuit...
if it is the fuse in the microwave, than it could be a sign that the magnetron is about to fail, or it could be a bad/erratic door safety switch that shorts from the oven's vibration... if it's the magnetron it is cheaper to buy a new microwave, if its the safety switch it can be replaced... not to expensive...
Mar 16, 2011 | Magic Chef MCD1311ST Microwave Oven
Blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Mar 01, 2010 | Magic Chef MCD1611 Microwave Oven
Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Sep 27, 2009 | Magic Chef MCB780W Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
