What is the function of the red WAN socket on the back of my BT Homehub 5?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
The red socket on the back of the HomeHub5 is to connect the Hub to an Openreach modem and thus provide a network facility for the whole house, wireless or via ethernet cable. Since the Homehuh 5 has the modem built in anyway it seems a bit redundant unless you have an RJ45 (ethernet) plug connecting to your telephone line rather than the more usual similar but slightly smaller RJ11 plug which goes in the grey socket.
By the way I thank you for your testimonial and could find no other way to answer it than answering this former question of yours! Maybe I'll find a better way later on !
Anyway all you need to connect your Netgear is to use an ethernet cable from one of the yellow ports on the HomeHub and then configure the Netgear as necessary to act as a wireless access point, or wired router. The HomeHub5 is however quite a good wireless access point working at both 2.4Ghz and 5GHz bands to give you the best speed, as well as the network ports (yellow) on the back.
Posted on Nov 09, 2014
  • Hans Zonne
    Hans Zonne Nov 10, 2014
    Thank you Mike. It seems to work although a bit slow. I will wait a few days and make my mind up. Cheers
    Problem Solver:
  • 6 Answers
The function of any WAN socket on a device is to input signals from outside your house (for example, the internet). Plug an ethernet cable into it and then the other end into a wired router and you will have WiFi throughout your house.
Posted on Nov 08, 2014
Hoe do I connect a sonytv KDL26EX302 to bt tv
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Televison & Video
I can't connect my kindle to my homehub. How do I find the hub password or re-set it?
if this is a bt homehub then the password for the wireless is on the hub on a sticker that says security key or network/WEP key, you will also have to press the hub button to allow the kindle to connect
Mar 28, 2011 | Computers & Internet
Can i put a Internet dongle on my home PC and connect to the Internet i don't have a bt line.
If you have a wireless router then yes you can use a wifi dongle. The only reason BT users can is that BT comes with a free wireless router (bt homehub) Max
Feb 11, 2011 | Dell Dimension 3100 PC Desktop
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
How can I make my canon mp140 wireless? I have a BT home hub on a secure network and it has a USB port, Is is possible to make this printer have some sort of wirless capabilities so i canb print from...
Its not an offical part of the homehub, but connect the MP140 and the HomeHub by USB, then on the computer you need to tell the PC that the printer is attached to the homehub rather than the PC. So on windows, start the add new printer wizard, and follow the steps on http://www.wallaceit.co.uk/Hardware/BT-Home-Hub---Use-it-as-a-print-server---Windows-XP-guide/80/article.aspx
Dec 11, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Im with talk talk broadband and have a bt homehub 2.0 wirless router. is there any way to reconfigure the router so that the internet can work?
I AM ON TALK TALK LAND LINE AND HAVE LOST MY B/B CONN THE MODEM SHOWS TWO GR LIGHTS AND ONE RED I HAVE DIS IT AND RECON IT AND PUSHED THE RESTART BUTTON BUT IT WILL NOT LOAD WHEN I CHECK CONN IT SHOWS RED CROSS BETWEEN COMP AND CONN
Nov 19, 2009 | Computers & Internet
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
DL-634M Wan socket
Try to update the firmware of the router first and hard reset it.
To hard reset it, press the reset button at the back of the rouetr for 30 secs then unplug the power for 30 secs and then plug it back in. Check if that fixes it.
Jul 05, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
