Power suply ok but set is st.by mode remot&panal switch not work
MODEL-LCDTVS2230YV-L
  • 3,506 Answers
Is this a sanyo or ????
Posted on Nov 08, 2014
Sharp LC-70LE733U won't turn on, remote or the power button? I was able to enter service mode and then test the TV it works fine.
After enter in Service mode press Ch down & Vol Down from LED back panel.
Select 8/10 page by pressing up & down button from remote
Select EEP , Press Ok button from remote
EEP - will show running
Switch off LED from main's and restart your LED will work properly.
Jun 08, 2017 | Sharp Televison & Video
Sansui LCDTVS2230YV is st.by mode or no work remot power buttan&no work panal power batan power suply 12v&5v is ok pless help
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 09, 2014 | Televison & Video
Lcd tv
Nov 08, 2014 | Televison & Video
How to wire front panal
You will need to open the computer case and check that the cables that run from the actual power button to the motherboard are plugged into the proper spot on the motherboard. Sometimes reseating the cable can fix this issue.
I think this is the link to your motherboard documentation: http://www.via.com.tw/download/mainboards/3/4/p4mapro533_r100.pdf
Check the page 2-14 or 2-15 and see if that helps you to identify the actual connection for your power switch.
Nov 14, 2011 | VIA P4MA Pro Motherboard
My tv auomatic off after 1 mi
1]...Please check that the sleep timer function is not set;
2]...Some tv's have a count-down timer & switch off if there is no signal input, either from the tv aerial, or av input;
Please check that the aerial is plugged in to the correct socket on the rear of the tv; test the aerial in another tv, to make sure it is working ok.
3]...It could be a problem with the remote/teletext panel?
for example, switching unexpectedly to standby, or changing channels unexpectedly?
4]...It could be a power supply fault;
for example, switched mode power supplies (SMPS) can cause problems; this could also cause the set to switch to standby mode.
PLEASE NOTE:
If the unit still switches off after 1 minute, even after checking the tv aerial is functioning properly, & is connected to the tv unit aerial socket ok, & the source is set to the tv aerial, then this could be indicative of an internal fault.
TV sets contain extremely high & very dangerous voltages, even after the tv has been unplugged from the ac power socket, on the wall, which could kill you!
FOR THIS REASON, & FOR YOUR SAFETY PLEASE DO NOT attempt to open or repair the tv unit yourself, unless qualified to do so - please take it to the tv repair shop;
only qualified tv engineers should attempt to carry out tv repairs.
I hope this information was helpful for you.
Thanks,
Steve.
Oct 01, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
Tv went into standby mode by itself & I cannot get it back on. Have tried unplugging it & have checked remote control which seems ok.
see if the TV timer is set to turn off after some amount of time. if it's not that it may be the power suply
Apr 07, 2010 | Toshiba Televison & Video
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
I need instructions and codes to program jumbo remote control
Try this, just be patient when programing it might take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Aug 11, 2009 | Brookstone 538744 Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
