'How do I find the lamp and change it?
  • 3,506 Answers
What make and model is this?
Posted on Nov 08, 2014
My headlighs are very dim - 2003 venture
So your dropping battery or alternator voltage before
it gets to the lights
Why is your mission
A dirty or loose ground, thus incomplete circuit
Something in the circuit before the head lights?
You need to unplug one lamp & put your volt meter to
the 12v feed to that lamp & turn them on
If you "don't "drop battery voltage there at the end of the line ,
then you need a wiring diagram to work your way back to
the offender.
So,lack of ground or resistance in the form of bleeding off
volts before the lamps, that should get full battery supply
Nov 18, 2012 | Chevrolet Cars & Trucks
How do I change the fog light bulb on a 92 Pontiac Grand Am?
I'm only going to guess for you
If you can squeeze under the front of the car or jack
it up to get under there
You should be able to reach up & get the lamp out
from behind
Need a flash light & some patience to get your hand up there
& figure it out.
The lamp is a halogen I would guess & fairly pricey
Do not touch the glass,hold it with a paper towel
Sep 28, 2012 | 1992 Pontiac Grand Am
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | HP Compaq Business Notebook NX9010
I just change the lamp but still the lamp hours shows the old timing
HelloYou have to reset the lamp time after lamp replacement. To reset lamp time follow these steps.[1] Press the power button, so that a picture is projected onto the screen.[2] Press the 'menu' button to display the 'main menu' screen, and press 'up' or 'down' buttons to move the cursor to select 'options-2'.[3] Press the 'enter' button to display the 'options-2' screen, and then use the 'up' and 'down' button to select 'lamp runtime'.[4] Press and hold 'enter' button for approximately 3 seconds. The 'lamp runtime' will change to 'time reset [power off]. Note: If the 'menu' button is pressed the lamp time resetting screen will be cancelled.[5] Hold down the 'power' buttonfor at least [0.5] seconds or press the 'power' button twice to turn oFF the power. This will reset the cumulative usage time for the lamp unit into Zero. OK.
Dec 20, 2011 | Panasonic PT LC75E Multimedia Projector
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
I cant figure out how to change the low beam headlight
You didn't say what year it was,so I will assume not
over 10 years old
In that case you remove the entire head lamp housing
to gain access to the back & the lamps you want to
check out or replace.
Jul 12, 2011 | Buick Rendezvous Cars & Trucks
Replaced ramp but can not get rid of flashing replace lamp signal every time I now turn on the tv. I tried the vol - & holding split/play button, but it didn't work
Hear many clicks too,after the tv projection lamp "LED" light indication LAMP flashes?Yes,than the board that call the Ballast board require changes too.This Ballast board only job are too help to ignite the tv projection lamp to lit up and work.
May 31, 2011 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
