Question about Ovens
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
    Genius:
  • Ovens Master
  • 1,848 Answers
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Posted on Nov 08, 2014
BADBOYJAY
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Posted on Jan 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Posted on Apr 22, 2009
SOURCE: Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Posted on Jun 22, 2009
When i using my oven, suddenly off i don't know how to fix
If there are no lights showing or electric fan or heat
Check the cooker trip / fuse on the main Fuseboard.
Should be 32 amp rating.
If Light works / or / and Fan but no heat then likely to be Cooker element. If its a double element or oven with grill you may still have reduced capacity to heat / cook food.
May 25, 2016 | Ovens
Bush ae56da. Why has main oven stopped working?
probably element gone get engineer
Dec 29, 2015 | Ovens
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Regards
John
Nov 02, 2014 | Ovens
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 14, 2010 | Ovens
Ovens Logo
180 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
