Question about Panasonic Heating & Cooling
I have a panasonic FV-11H1 exhaust/heat fan. The heat blower stopped working. This product was discontinued and replaced with a unit thats a liitle larger than my current one. Is there a fuse that nee
I have a panasonic FV-11H1 exhaust/heat fan. The heat blower stopped working. This product was discontinued and replaced with a unit thats a liitle larger than my current one. Is there a fuse that needs to be replaced inside the unit. Power is good from the switch to the fan.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 165 Answers
Could be a fuse but is most likely the windings or brushes on the motor. Would have to replace motor or take it and have it tested / fixed
Posted on Nov 09, 2014
  • 261 Answers
SOURCE: In-dash fan does not work
the blower motor resistor located in the heater A/C panel usualy under the glove box
Posted on Nov 18, 2008
SOURCE: Heater Control Switch Only Works on High
Your problem is probably a part called the heater resistor block or board. When this part burns out you will only have high speed on the fan. On my 1999 voyager it is located on the firewall and it snaps in a hole in the firewall. This is under the hood behind the alternator.
Mine had a multi pin black plug plugged into it. Unplug the plug and
you should be able to pull the block out insert new block and plug plug back in and it should come to life.
Posted on Nov 27, 2008
  • 6982 Answers
SOURCE: 1983 Chevrolet Suburban Heater fan not working
check relay and blower resistor...likely the relay is bad.
Posted on Mar 15, 2009
jigsaw_9077
  • 308 Answers
SOURCE: 1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Posted on Aug 04, 2009
SOURCE: How to access ac blower and fan switch, 1999 Volkswagen Beetle?
ac wont work light doesnt come on defrost dont even work wat do i do
Posted on Jun 08, 2012
The heating element and heater fan in our FV-11VHL1 vent unit stopped working. How do you get at the heater box assembly to replace the fuse or thermostat? It appears to be screwed together to the heater...
Hi Ricatoni,
The procedure for doing it as as follow , patience is required..:)
First you should remove the cover by pulling down and squeezing the wire arms on each side.
Then You need an extra long screwdriver to remove the entire motor/fan/light assembly from the housing (8 screws total).
Place the assembly on the floor and look for the fuse on top.
The fuse is on the motor and not near the heater portion.
It is a ceramic, not glass, cylindrical fuse, 20 amps, 125 volts.
This fuse is sold as a microwave oven fuse & costs about 2 bucks at a hardware store.
Then you can replace, hence reinstall and then you're done.
Hope this helps ..:)
Sep 06, 2011 | Panasonic WhisperWarm FV-11VHL1 Compact...
Fan will not work
mcdevito75 here, Most likely yes, Check the fan by carefully turning it just a liitle by hand, also check for heat at the fan motor base, close to the ceiling. If heat or fan won"t start by hand, replace it.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Panasonic fv-11vhl1 fan frequently makes noises while running; unit is 5 yrs old; all user maintenance has been performed. Is fan cage repairable/replaceable?
MOTOR SOUNDS LIKE IT IS GOING BAD, YES THEY ARE REPLACE ABLE, FIND THEM AT ONE OF THE ONLINE SUPPLY HOUSES, NO NAMES BUT IT RHIMES WITH DANGER
Jan 17, 2010 | Panasonic WhisperWarm FV-11VHL1 Compact...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Replacement bulb for Panasonic FV-11VQL4 does not fit
YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
Mar 12, 2017 | Panasonic Kitchen Appliances - Others
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
Heating & Cooling Logo
183 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
