Lcd tv remot&front panal switch not work set st.by mode
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Posted on Nov 09, 2014
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Posted on May 25, 2008
SOURCE: how can we set sylvania tv to game mode from the front panel?
hit menu and then hit the up volume button once and thn you should have it by the way i cant play games on mine how r you playing games on yours?
Posted on Feb 22, 2009
Sansui LCDTVS2230YV is st.by mode or no work remot power buttan&no work panal power batan power suply 12v&5v is ok pless help
Nov 09, 2014 | Televison & Video
No display
On the front panal you should have some config buttons for the monitor setup. One of the buttons also switches video input mode but you have to hold it for a couple of seconds and it switches from dvi mode to analog. That may fix it.
Mar 16, 2014 | Dell E152FP 15" Flat Panel LCD Monitor
Remote Control Not working
JUST GOOGLE THE BRAND OF THE REMOTE AND YOU WILL FIND A CODE FOR IT.
Jan 27, 2014 | Televison & Video
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
My TV panal has ben loked. How can i remove this??? TV name: IGO classic 20"
SOME ONE HAS PUT THE T.V. IN DEMO MODE, USE REMOTE - MENU TO SETTING DEMO MODE OFF.
Sep 09, 2010 | Televison & Video
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
Soniq lcd tv 17 inch have no remote how do i select the pc mode or av mode?
go through the tv menu set-up, using the front buttons on your tv set.
Oct 13, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Att uverse remote not working with Phillips lcd?
I just did some research on this problem and found a fix. If your tv has a powersaver feature on it turn it off i put mine on standard and my remote works fine now. weird but it works!
Dec 29, 2008 | Olevia LT32HVM 32 in. LCD Television
Rca 32v432t
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
