I used a voice recorder and when I tried to listen back to it, it had the tv and other background noise. What can I do to pull the voices out to understand it better without the other noise?
    Problem Solver:
  • 16 Answers
If it has a switch labeled conf/dict , put this switch in the dict mode. This switch is a record sensitivity control, in the conference position it will pick up almost any noise in the room. In the dict,position which is short for dictate, it will have less record sensitivity and will only pick up sounds very close to the microphone and eliminate background noises
Posted on Nov 24, 2014
  • 16 Answers
SOURCE: How do I Change from default language back to English?
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Posted on Jun 17, 2008
  • 5 Answers
SOURCE: Software downloading
VoiceStudio 2.03 Software for RR-US395 or any RS-US3xx (RSUS3..) or Driver M66291GP
http://rapidshare.com/files/139328793/PanasonicVoiceStudio2.03.zip.html
Drivers voice recorder (instalar first, before software)
http://rapidshare.com/files/139329731/driverRRUS395.zip
http://rapidshare.com/files/139330443/driverRRUS360.zip
Manual
http://rapidshare.com/files/139330604/UsersManual-Panasonic-RRUS395.zip
I managed to have mine to work.
Posted on Aug 22, 2008
SOURCE: w10 olympus digital voice recorder
i want to transfer my files from my
W10 olympus digital voice recorderto my p.c but i dont have the cd-rom for the installation of the programme. i WOULD APPRECIATE ANY HELP
Thanx!
Posted on Nov 21, 2008
SOURCE: Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Posted on Dec 29, 2008
  • 919 Answers
SOURCE: How can I transfer files form a VN-2100PC recorder
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Posted on Mar 09, 2009
Get rid of background noise
Well Adam,
was the environment already noisy?
Well but there is a program (Nero Wave Editor) which can help.
On the interface, click ENHANCEMENTS on the top and then select NOISE REDUCTION and it will present you with some other interface with sliders and then you move then more to the right.
Standing by anyway
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Can't get rid of background noise on my marantz pmd660
Did you ever find a solution to this problem? I have tried new AC adapter cord and it still has background noise. The only time it doesn't is with the batteries.
May 15, 2012 | Marantz PMD660 Digital Voice Recorder
When I listen to a recording there is a "zzz" noice in the background. What do I need to adjust to reduce this background noice?
This could be noise given of by the drive motor. It,s nothing to worry about, but if it gets much worse then the motor will have to be replaced.
May 20, 2010 | Audio Players & Recorders
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Need to clean up background tv noises to discerne human voises or other sounds?????
How can I clean up a voice recording. There is alot of background noice drownding out the voices. Any help would be great
Apr 18, 2009 | Olympus VN-2100PC Digital Voice Recorder
I HAVE AUDIO RECORDINGS THAT HAVE LOTS OF BACKGROUND NOISE. WHATS THE BEST PROGRAM FOR CLEANING UP BACKGROUND NOISE, I DOWNLOADED A FREE TRIAL OF AUDITION. CAN I USE THIS PROGRAM? I HAVE NO CLUE HOW TO...
a bit late, only just saw this question. my understanding is that clearing up background noise is a specialist task. if you look at a sound wave it's really difficult to discern the main wave from additional noise. and although its possible to edit out the background of a photograph, that gets a lot trickier with a video if you follow my metaphor. the best most of us can do is open the file in a sound app (i'm on a mac so i use quicktime for this) and find the menu option to raise the volume. Now its absolutely possible that someone has come up with some new software that i haven't heard of yet of course. however good practice is; make sure you record at a good volume to start with- either do an audio test and listen back or set the levels with a headphone.
Mar 19, 2008 | Olympus VN-2100PC Digital Voice Recorder
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
A lot of background noise when playing back.
The pic looks like a TRC5880? If thats the case they are naturally quite noisey. The motors vibrate too much in my opinion. Theres not much you can do with it unfortunately. Suggest a new recorder or get that one repaired.
Nov 07, 2006 | Sanyo TRC-5830 Handheld Cassette Voice...
102 people viewed this question
 Grubhead
Grubhead
