Lennox MS8 heat mode never shuts off
I just had a Lennox MS8 installed. In "heat mode" the unit runs and never shuts off. I understand the unit has to cool down before shutoff once the temp defined is reached. I tried using the unit and remote (I FEEL) temp control, but neither seems to work.
Have you ever got this resolved. I am experiencing the same issue.
Posted on Nov 19, 2015
  • 35 Answers
Is it the blower that doesn't shut off or the heating unit?
Posted on Nov 08, 2014
Testimonial: "Its both he unit outside and inside"
  • Paul Gallant
    Paul Gallant Nov 08, 2014
    it sounds like there might be a problem at your thermostat.
Lennox gas package unit blower motor will not run inheat mode with fan in the auto mode but will run in all other modes including ac
There is a Bi-metallic klix-on switch in the heat chamber that senses when there is a temperature rise in the fire box. It supplies voltage to the fan relay when in the heat mode. It's function is to delay the fan coming on so you won't get a blast of cold air out the vents until there is enough heat built up in the heat chamber. Not very expensive either. There is a number on the switch that indicated what temperature it turns on. Get an exact replacement! Any appliance repair parts company will have them.
Sep 24, 2014 | Heating & Cooling
Lennox troubleshooting
Your control may a defected relay to the blower under heating mode. If that is the case you will need a new control board or replay.
Feb 05, 2014 | Heating & Cooling
My Lennox MS7 heat pump was installed about a year ago and hasn't had any problems until last week. It has started changing settings (like on or off, higher temperature, light on or off) without prompting...
Go to the unit locate the control module. Take wires to thermostat out. Now jump from R to Y your AC should come on. Jump R to W your heat should come on. Jump R to G your blower should come. If you have done these and it stay on or run as it should then you need a new THERMOSTAT.
Oct 26, 2013 | Lennox 7 Series MS7-HO-30P MS7-HI-30P Heat...
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
http://www.lennox.com/locate/default.asp
Jul 06, 2010 | Heating & Cooling
I have a Goodman PHK036-1 unit outside and it had a Lennox Thermostat. I want to replace it with a Lux DMH110 Thermostat and I need to know the wiring for this. I had someone help me last night but the...
Disconnect all wires to start.
1)Go out to unit shut off power and remove electircal panel.
2) Locate the terminal board where thermostat wires are connected. Write down where each color goes to
each letter and then try to do this at the thermostat.
R= Red wire= Power
G= Green Wire= Fan Leg
W or W1= White Wire= Heat Leg
Y1 or Y2= Blue or Yellow Wire= Cool Leg
C=Brown or Black or Orange= Common if used
Jun 27, 2010 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Does the lennox g14q3-80-c1 have to have the air intake from outdoors? i recently had a tankless water heater installed and the installer removed the air intake from outside to vent the water heater.now...
Yes, it needs to vent from the out doors. I dont understand why they would have removed the air intake (flue) from the unit. Especially in the Furnace room where the heater will be producing gases of its own and that can be dangerous. Check with Lennox or call back out the Install manager of the company that installed this unit. Unless where you live there is code to say that it can vent from in doors. But in California it has to vent outside
Jan 03, 2010 | Heating & Cooling
My Lennox Air conditioner only heats
It is possible that it's the thermostat. When you turn it into cool mode, does the unit come on at all or is it silent? If nothing is coming on, then it's likely it's the tstat. Did the tech check the refrigerant charge while he was there? He should have checked it with the auxillary heat off and the unit just in heat mode. Make sure that the condenser unit outside is coming on when you are calling for cool, If you turn it on and everything comes on, go outside and put your hand on the large copper pipe coming into the unit. In cool mode, this pipe will be cold to the touch and in heat mode, the pipe will be warm to the touch. There isn't much you can do on your own with the exception of changing the tstat. If you can answer some of the questions I have posed, I can try and give you some more answers. Just remember that a check up doesn't mean its a guarantee that something won't happen the next day, it's just that everything was in working order at the time of the checkup.
Mar 21, 2009 | Heating & Cooling
Heating & Cooling Logo
189 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
