Question about Superior Lennox Blower Thermal Sensor - BTS
I just had a Lennox MS8 mini-split installed. The problem is it never shuts off in heating mode.I've tried using the unit's and remote to control the temp, but neither seems to shut the unit off when
I understand the unit needs to run after the temp is reached to cool the unit down before shutoff
Lennox MS8 heat mode never shuts off
Is it the blower that doesn't shut off or the heating unit?
Nov 08, 2014 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Remote control malfuction
04Feb14
In some states and provinces of Canada, the Lloyds 'remote' CANNOT be programmed into cable vision providers!!!!!!!!!!
One provider 'Shaw Cable' has never heard of Lloyds.
What's up with this.....having to use Lloyds remote to adjust volume and mute, while using Shaw's remote to channel change.
That's just awful. Archie Bunker has it bedda.
Feb 04, 2014 | Klimaire Universal Mini Split Remote...
My Lennox MS7 heat pump was installed about a year ago and hasn't had any problems until last week. It has started changing settings (like on or off, higher temperature, light on or off) without prompting...
Go to the unit locate the control module. Take wires to thermostat out. Now jump from R to Y your AC should come on. Jump R to W your heat should come on. Jump R to G your blower should come. If you have done these and it stay on or run as it should then you need a new THERMOSTAT.
Oct 26, 2013 | Lennox 7 Series MS7-HO-30P MS7-HI-30P Heat...
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Computers & Internet Logo
88 people viewed this question
Top Superior Computers & Internet Experts
David Payne
David Payne
Are you a Superior Computer and Internet Expert? Answer questions, earn points and help others
