Question about Electronics - Others
Panasonic inverter economic ac H 95error code coming. What's problem
Code h98 Panasonic could it be a fuse?
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit. It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
(Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these inverters. You can find an authorized US Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here.)
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see my help files here, here, and here. Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 13, 2017 | Panasonic Microwave Ovens
Code for 1100 watt panasonic genious premium H98
That code might mean there is a problem with the inverter board. To test it, use the procedure outlined here:
http://educypedia.karadimov.info/library/Inverter.pdf
Sep 12, 2016 | Panasonic Microwave Ovens
What fault is it whenH97 comes on the microwave oven
could be serious or minor fault ,have an electrician or engineer measure the the ac current AT THE MAINS PLUG
1 = OVER 1 AMP,the magnetron or the inverter power unit is faulty
2= 0.8 AMP OR LOWER,HALF AMP,problem is dpc board or the wireing to it
Replacing,repairing or testing of the inverter power unit is best left to professional engineers with acess to panasonic test procedures high voltage high current = danger of death.
if 1.5 amps or so and magnetron suspect check with continuaty tester for open circuit fillament or wireing to
Jan 11, 2015 | Panasonic Microwave Ovens
How to i get the timer on a Fujitsu Halycon inverter to repeat every day?
is not possibily,to any ac.the timer run just for 24 hours.on the power surce of your ac you can make a timer control programms, who take or give energy to your ac inverter(you put the ac inverter to run , and when the energy is shut down ,the ac inverter is stop working and when the energy is come back the inverter start working)
Nov 26, 2013 | Heating & Cooling
Panasonic inverter 900w microwave fault code h97
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
1- Panasonic 7'' monitor model # CQ-VA707WEUC 2- Panasonic brain model #YEPOFX3799 I NEET THE id CODE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Panasonic BT-LH900
Electronics - Others Logo
46 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
