Question about Air Tools & Compressors
Where would I find operating info and a manual for my Delta Shopmaster 2 Gal. portable air compressor Model # 66-240?
I purchased this unit older unit off Kijiji and have not been able to locate any online information about using or maintaining it. Hope someone can help me.
Gagg
  • 4 Answers
SOURCE: portable air compressor wont turn on
1st check for power at the pressure switch. Take the cover of the switch and make sure you have line voltage at the terminals from the wall outlet.
if no voltage>replace cord or plug end with proper gauge wire.
If voltage, then, while you have the cover off of the switch **Make sure it is not plugged in** and operate the on off switch and visually check the operation of the switch. You should see some flat copper terminals that, when the switch is turned on, kinda rotate and drop onto some other copper terminals. The connection is kinda like points on a old car ignition, little pads on each copper thingie contact each other. I have seen these little pads become pitted and burnt from arcing. Try to clean these with a small file or pick if they are corroded. Get some electrical contact cleaner and clean the switch completely, *it is not only electrical, but is also mechanical*. Switches will intermittantly work, replace the whole pressure switch if there is heavy wear, charring or working intermittantly.
If this is all good, check the wires coming out of the switch for power to the motor, replace if necessary. If this is ok..
You probably have a bad motor. I have not had much success in revitalizing motors, its usually better to just replace it.
Posted on Nov 21, 2008
hdpanama
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
  • 4088 Answers
SOURCE: I have a Craftsman air compressor twin cylinder, 2
Go to: www.searsparts.com
The pressure control switch which the compressor usually pumps into and is mounted on the tank, contains a backflow check valve, the pressure regulator switch, and a compressor pressure release valve. It's probably available only as a complete unit. The pressure switch itself is usually a microswitch that can be obtained locally at a hardware or appliance parts house. Make sure that the pressure switch adjustment hasn't been set higher than the compressor can reach. If you remove the cover, you can watch for mechanical movement at the switch when it is supposed to shut off. Don't poke at anything in there with metal tools--220 volts will give you a lethal shock!
Posted on Oct 30, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have a Speedaire model 3z492 air compressor. The
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Posted on Nov 09, 2009
Need owners manual for delta shopmaster tp300
Go to http://servicenet.dewalt.com, put your model number in the search box and you'll be able to view/download the parts breakdown and owner's manual.
May 04, 2012 | Delta TP300 Shopmaster 12-Inch Portable...
I have a delta portable planer, model#22-540 type 2. I need to know how to change the blades.
It is involved so I recommend going to "dewaltservicenet.com" and under manuals on the left hand side type in your model number and it will redirect you to a page so that you can download the owners manual, it is 17 pages long and the area you need is around pages 10-11 which deals with blade changing. REMEMBER to unplug the tool before starting this. Let me know if you need more assistance
Jun 27, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I need a manual for a Delta TP300 Planer
you might want to try Dewaltservicenet.com and you can type in your model number to see if they have manual available. If you still have problems let me know.
Jun 28, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Where can I purchase blades for the Delta BS100 bandsaw?
You have a couple options, you can buy direct from Delta by going to Dewaltservicenet.com and clicking on the Delta icon on the top or easier go to Ereplacementparts.com and down at the bottom of the site you will find accessories click on the saw blades and pick what you want. Let me know if you need more info.
Mar 20, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
How to change planer blades on the Delta PT400LS 12.5" planer?
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Nov 19, 2008 | Delta TP300 Shopmaster 12-Inch Portable...
Air Tools & Compressors Logo
76 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
