Question about Frigidaire Washing Machines
How do I turn off delay start on my Frigidaireaffinity double loader
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Norma Eggenberg, thanks for your post!
I understand that you would like to turn off the delay start on your Frigidaire Affinity washer. Typically, to remove any type of feature you should be able to press the cancel button and it should revert back to the original settings. If this does not help correct the issue I would recommend resetting your washer. To perform a reset you would need to disconnect power by either unplugging the power cord or flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Posted on Nov 10, 2014
Front loader dryer press the start button it has a click noise(assume the door locking) than light blinks but the drum doesnt turn for 2 days it would star/ stop start/stop but now it wont even turn
sound like there might be a delay setting that may have got switched on by accident. Call or email the company that made it and ask for the tech department they may be able to tell you if you need a service call.
Oct 03, 2017 | Dryers
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
GE wcvh6400j1ww Front loader washer
It is most likely the water valve that your going to have to replace. its the part inside the machine that the hoses hook up to. But first you should check your machine's error codes to make sure you are going to need to change that part. First make sure the display on the machine is clear. unplug the machine for 30 seconds. when you plug the machine back in then push signal, delay, signal, delay and it should say t01 on the display screen. turn the nob til it gets to t02 and then push the start button it will give you the error codes for your machine.
Nov 26, 2011 | GE WSXH208A Front Load Washer
Bosch Classixx 1200 wont start. Ready light is on, door is firmly shut, but start button does not do anything?
these things can be confusing! you may have it set on 'delayed start' or 'soak'- check the other indicator lights! 'soak' would fill and pause for a while, while 'soaking'- 'delayed-start' can be set for an 8 hr. delay on our fridgidair front-loader. don't know about the bosch!
check settings. if ready light is on, there doesn't seem to be a problem with door latch.
good luck!
Oct 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have the code for my 2002 land rover discovery i just dont know how to put it in, any ideas thanks
To enter the EKA:
Close all the doors.
Turn the key in the driver door lock to the unlock position and hold there for at least 5 seconds until the alarm sounds once. Then return to centre - always ensure you return to centre and do not delay more than 10 seconds between turns, or hold in the position for more than 5 seconds or you will reset to the start. Turn to full extent of travel.
1st Digit turn to unlock the number of times specified.
2nd Digit turn to lock the number of times specified.
3rd Digit turn to unlock the number of times specified.
4th Digit turn to lock the number of times specified.
Finally turn to unlock once more. If it is correct a double bleep will sound (single bleep is incorrect code)
You now have a 5 minute delay - don't open any doors. The anti-theft indicator will continue flashing once every 2 seconds for the five minute period. When this goes out, open the door and start within 30secs.
After 3 failed attempts, the security system invokes a delay period of 10 mins during which the system will not accept any further attempts to enter a code.
Oct 19, 2009 | 2002 Land Rover Discovery Series II
Mp3 player turned into ALi Boot Loader usb device
Contact the manufacturer and have it send the firmware upgrade + the application to upload it.
Mar 15, 2009 | Audio Players & Recorders
Reload software 507
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
Open BlackBerry Desktop Manager and double-click the Application Loader icon.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
On your computer, click Start > Settings > Control Panel.
In the Control Panel, double-click the System icon. The System Properties window opens.
Click the Hardware tab of the System Properties, and click Device Manager.
In the Device Manager, double-click Universal Serial Bus Controllers.
Right-click the first USB root hub, and click Properties.
In the Properties window, click the Power Management tab.
Clear the Allow the computer to turn off this device to save power check box.
Repeat steps 5 to 7 for all other USB root hubs.
Restart your computer.
Cause 4
Resolution 4
Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
Re-install the BlackBerry Device Software using the Application Loader tool.
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
