Question about John Deere Garden
ADJUST THE GOVENOR ON MY LT 155 John Deere lawn tractor
Need to know what position the throttle lever should be in when making the govenor adjustment and the direction of rotation of govenor shaft when facing the carb
  • John Deere Master
  • 1,169 Answers
This should be Kawasaki engine; although, it could a Kohler. The IPL on this doesn't specify which engine it has. It would nice if it did where I could look the engine's service manual but the following should be what you need.
You place throttle in full throttle position. You need to watch the linkage at the governor shaft for which it turns as you go to full throttle then you would continue turning the governor shaft in that direction until it stops. From there you tighten the retaining bolt or nut and you should be good to go.
Posted on Nov 08, 2014
  • 138 Answers
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Posted on Sep 06, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
daneinwv
  • 124 Answers
SOURCE: How do I adjust valve rods and what's the
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 06, 2010
How to adjust clutch levers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 26, 2016 | John Deere Garden
If brakes are not locked together on steep ground the John Deere tractor will kick out of 4wheel drive and run away.
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/...A9/Output/OMM139226_A95.html
Slow down before you make a sharp turn or operate on a slope. ... Before starting engine to drive tractor, adjust operator seat to desirable position. ..... If lock does notdisengage, depress one turn brake pedal, and then the other. ... The 2-wheel drive (2WD) / 4-wheel drive lever (A) enables the tractor to be operated in two or ...
A Guide To Safe Farm Tractor Operation - National Ag ...
Nov 23, 2015 | John Deere Garden
How do i syncronize my john deere lt 155 blades
they should not be able to hit each other. remove them and make sure they are not bent.
Jul 14, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
1970 John Deere 4020 Diesel, Engine speeds up by its self, I goose the throttle and then it will idle down. pretty sure it is a govenor problem. How do I fix this?
spring is broken/stretched out on govenor linkage bar that runs from air damper flag to injector pump and i would expect a 1970 to be needing a new spring about 5 years ago
Dec 12, 2013 | John Deere Steel Chain/farm/tractor/john...
Lt 166 govenor adjustments how to
Your governor should not need adjusting unless someone moved it and you want to go back to factory setting. Having said that. You will loosen small nut on bottom of governor, follow the travel of governor to watch the throttle in wide open position. Hold it in that position then with needle nose grip the center of stud coming out of bottom center of governor and move this all the way in same direction as wide open throttle, then snug it up and your done. Good luck.
Jul 22, 2013 | Garden
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
Adjusting belts & veriato on a John deere model 216 garden tractor
Belts on the variator system are spring loaded, they 'self-adjust'. If they are not working correctly, they are worn & the center pulley of the variator can be worn so it 'cocks' sideways as the belts work.
*the only adjustment is the sicronizing of the variator to the foot pedal. This only effects the lever in the full back position. If it is out of adjustment, the tractor will stop in the full back position.
Nov 23, 2009 | John Deere Garden
Garden Logo
225 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
